Date: 05/13/2021 05:29 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 07/21/2017 11:49 am
Date: 01/19/2021 03:56 pm
Date: 08/24/2018 02:50 pm
Date: 10/04/2019 08:43 pm
Date: 02/18/2017 04:44 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
  • Online today: 577
  • Guests: 442
  • Total: 442
oddly low temp reading
Started by Sir Hugh, April 06, 2006, 05:36:10 AM
Sir Hugh
Thanks guys I'll check it out, though I am just hoping its a bad thermostat thats making the car run cooler.  We'll have to see...  :)
Loving my plum 1978 Pinto Hatchback.  He has a rebuilt engine and is running like new. Beautiful. He still needs a new paint job though.
goodolboydws
Another few possibilities:
The compression pressure or combustion efficiency has dropped considerably in the engine, due either to cylinder/piston ring wear or maybe only from needing a valve job. With a worn,  or low compression engine MAKING less heat in the first place, there is less to warm up the coolant. Higher mileage, worn engines typically run cooler, but just how much cooler depends on a lot of factors...
Suggest doing a compression test, it's cheap and may pinpoint the source of the problem if compression is down.
Ignition timing has changed considerably.
For example, maybe you aren't getting any vacuum advance anymore, due to a vacuum leak.  Simple to check with a timing light.
The thermostat could be stuck open?  I had a truck that did the same thing with the temperature gauge.  The thermostat was stuck open and the gauge would hardly read. I replaced the thermostat and everything went back to normal.   However, my truck did not burn oil as a result?
pintoracer02
That is my best guess.  If the motor had an air pocket or there was a break in the copper line that goes to the temp guage it could give a false reading.
Bass Ackwards
Sir Hugh
Hey, i want to know if anyone has any ideas on what is going on with my car.  So because my car chooses to burn oil, I am constantly keeping an eye on the gauges.  Lately, his temp gauge has been dropping to lower and lower temperatures.  Back in the day, when he was warmed up, he'd be about 185. Now he has dropped as low as the gauge can read as if he hasn't been running for an hour.  So any thoughts?  ??? Could something have happened to the thermometer/regulator, it probably is still from '78.   :)
