Date: 10/31/2018 12:00 pm
Date: 08/13/2018 02:46 pm
Date: 12/15/2018 02:21 am
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 09/12/2018 04:07 pm
Date: 10/25/2019 03:30 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
  • Online today: 266
  • Guests: 258
  • Total: 258
Pinto transmission
Started by ccmhockey12, April 02, 2006, 10:23:11 PM
The question is: "what are you tring to do?"
Swapping a good tranny for a good tranny? A N/A 2.3 with a good c3 is not bad, but the c4 is stronger.
A c4 will fit a 2.3 IF you have the correct bell.
C3 has 13 pan bolts, the c4 has 11.
Sounds like a lot of work for a demo car.
your 74 pinto should already have the  c4 tranny.
ccmhockey12
So will a C4 tranny fit the 2300cc engine too? I also have a '74 pinto, not sure if it has a C3 or C4 transmission on it. I know I'm going to make a lot of pinto lovers mad at me, but I'm planning on wrecking my '77 pinto. I rebuilt my engine and I have a C3 tranny on it, but i read somewhere that they zoop. Is a C4 better than a C3? or will i just be wasting my time swapping trannys? I'm just trying to get the best angine and tranny set possible. Thanks for the help!
P.S. The C3 is a perfectly good transmission.
The XR4TI Merkur had the C3 tranny. They eventually went out, but a carburated 2.3 will have a hard time hurting a C3.
It is just costly to rebuild.
Hello ccmhockey12,
The C6 tranny has the bell house as part of the case so it will not work.
For referance.... I have a 1973 E300 1ton Ford van and it has a factory C4 tranny.
Many of the 2300cc 1974-75 Pintos have C4 trannys too.
:welcome: to the Ford Pinto group.
ccmhockey12
I have a '77 pinto, 2.3L 4cyl. I want to know if its possible to put a C6 transmission to it. If so what do i need and where can i get it. I have the stock C3 transmission, but i want something better. If not a C6, is there anything that I can put to the engine that will be better than the C3. Thanks!!
