Date: 07/01/2019 03:17 pm
Date: 02/28/2018 09:37 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Date: 10/24/2018 07:35 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
nos core support
Date: 01/03/2020 09:39 pm
Date: 12/10/2017 01:14 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
  • Online today: 2,670
  • Guests: 588
  • Total: 588
Electrical Problem
Started by pinto1955, April 01, 2006, 05:40:48 PM
pinto1955
Thanks to all of you who replied on this subject. Pintoney I'll call you this Saturday or Sunday if that's ok. I've been out of town last week still working on hurricane damage from Katrina & Rita. Saturday is my best day if it doesn't conflict with your schedule. Please respond if that time is ok. Thanks again, Don
1972 Ford Pinto SS/MC, HP 2.0, 4 speed, 9" full spool w/6:50 gears
Original74
I was going to post my experience with this, as just yesterday I replaced the ignition switch in mine, was right there with you on what you describe. But.....how can I trump the experience of the Pintony-Meister? I trust you two will talk as he has detailed above.
The reason I replaced my ignition switch was the same issue as you describe, no crank when in starting position. New switch did not help me. As stated above, there is adjustment in the location of the switch. If you pull the pin in the switch all the way towards the steering wheel, that is the ACC position. Push it in one detent and that is the LOCK position. I positioned mine in the lock position with the key in the same position. Verified that when I put the key in ACC, it pulls the switch to that position, then it is synchronized with the switch.
I believe my continuing problem to me my neutral start switch. I too can remote start from the solenoid, but even with the key in the crank position and moving the auto shifter through all positions, I get no crank. I found a post and pic by Pintony showing the square 4 pin connector from the tranny that is the neutral start and backup light switch. I need to figure out which wires are the neutral start. I am going to get under it this morning and remove the neutral start switch from the side of the tranny, that way I can get the color code right. Will probably be looking for a new switch, hopefully a standard Ford part. Thank goodness for Ebay.
Well, I said I would not trump the Pintony-Meister, but just shared my experience. Can't make Tony mad, he is scheduled to stop by my house Wednesday on his way to CA. Don't want to make him mad and have him pass me up!
Hope this helps someone. I don't want to bypass the safety of the neutral start switch long term, but might have to jump around it to get me going until I can find a switch.
Dave
Dave Herbeck- Missing from us... He will always be with us
1974 Sedan, 'Geraldine', 45,000 miles, orange and white, show car.
1976 Runabout, project.
1979 Sedan, 'Jade', 429 miles, show car, really needs to be in a museum. I am building him one!
1979 Runabout, light blue, 39,000 miles, daily driver
Hello pinto1955,
Call me on sunday and I will tell you how to fix your starting problems.
from Pintony
1-618-339-5047
fast34
But is it adjusted properly??  There should be a little adjustment in it.
pinto1955
Hi Rex,
Thanks for the reply but the rod is still connected to the switch. I stripped away all the plastic mouldings on the colunm and partially dropped the column to check it and make sure the pin was also intact. Let me know if you have any other ideas. Thanks again, Don
73pintogeek
Hey Don,
I believe the problem is mechanical...there is a rod inside the column that run`s from the ignition switch down to the actuator...when you re-installed you may have jarred it loose somehow...this has happened to me before...just a thought...anyone else have any idea`s?
Rex
A bad day workin` on my Pinto is better than a good day at work!
pinto1955
Hi,
I  hope someone can please help. I just finished restoring and old 1972 Ford Pinto sedan. I turned the car into and old NHRA Super Stock Modified Compact with an HO 2.0. I've been working on it for 2 1/2 years and it's finally finished. Problem is about two months ago i lost the keys and had to have a new cylinder put in. When I reinstalled the sterring column and turned the key it initially wanted to start and then it quit. Now I have nothing when I turn the key. The lights come on but won't crank. There's power at the fuses, at the actuator switch and on one side of the solenoid. I've replaced the solenoid in case it was defective and still nothing. The only way it will turn over is if I cross the solenoid terminals with a screwdriver. I've even tried switching the wires at the solenoid and still nothing. I would really appreciate any help or advice. If anyone could call me 832-563-8427 or write back to this web site or my e-mail dcorneau01@ev1.net I would be very grateful. Thanks for your time, Don
