Date: 10/31/2018 12:04 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
Date: 03/17/2019 03:57 am
Date: 08/24/2018 02:50 pm
postal pinto
Date: 06/03/2020 09:31 am
Date: 05/18/2020 10:22 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Date: 01/28/2019 05:15 pm
  • Online today: 1,292
  • Guests: 549
  • Total: 549
side pipes
Started by robw, March 18, 2006, 05:34:05 PM
gearhead440
Anyone have pics of a pinto with side pipes?
50" side pipes...
Not sure where the shocks thing came from???
Quote from: ford guy on March 26, 2006, 10:22:21 AM
yes but on a v8 pinto. can get them any where probly 50 inch
and ford type air shocks will fit  been there did that
but remember  this is  tin  and possible to much extra force could rip out the shock pockets---ok  its happened before   especialy  if you hit a serious pot hole.
wayne
50 "  :what:, "ford type air shocks" ????? Dude, whats up man......... :wow:
ford guy
wayne
Im thinking that any side pipes would probably get busted up  over the first speed bump.
Well, anything can fit given enough time and money (and a big hammer).
The air shock answer is no, not directly, unless you use the (lower) shock mount plates from the MII with the MII shocks, then yes.
I don't think MII's came from ford with air shocks, but if a company makes them for the MII, then they should fit a pinto with the mentioned plates.
Keep in mind that if you are trying to "lift" the rear of a pinto with air shocks, that the stock shocks are set to counter torque with one in front and one behind the axle. This could have an adverse effect on the handling of the car by pre-loading the springs in opposite directions.
robw
I have a now stock 1980 66000 original miled 2.3/auto, all I have done is get it running and add a set of autometer phantom guages to the dash in front of the passenger seat above the glove box and also new rear springs. I am wondering if any of you guys have side pipes on your ponys, whether it be both sides or one side functional.also i have heard that mustang II air shocks will fit on the back, is this true or not. thank you in advance
