Date: 01/30/2017 01:48 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
postal pinto
Date: 06/03/2020 09:31 am
Date: 07/17/2018 09:22 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 05/21/2019 11:50 am
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
  • Online today: 488
  • Guests: 460
  • Total: 460
I have a red wire with a blue plug where does it go
Started by shockerlover, March 18, 2006, 10:50:53 AM
imhoppy
Lugnut is correct its for A.C.I have the two on my 78. I was worried that if the smog guy saw 2 wires unhooked he'd give my pony the hook.
lugnut
Its for the idle (anti-diesel) solenoid, and/or the a/c idle up solenoid if you have ac. Both are from the same source- hot in Run only i believe.
earthquake
It's probobly the wire for the electric choke,though the plug for that is usaly white.
fast34
Maybe it is a pre-wired plug if the car had A/C for the idle-up solenoid?? :what:
I'd like to know this too as I got the same thing that seems to go to nowhere. Maybe it goes to the idle control solenoid?
shockerlover
i just realized i put from back to front...it actually runs from the front of the car and gos in between the carb and valve cover and is in a cluster of wires.....i need this asap....later
shockerlover
Yes I have a 80 pinto with the 2.3 motor.....I found a red wire with a blue plug that looks like it plugs to a flat piece of metal....it runs in between the carb and valve cover from the back towards the front....does anyone know where it might go?????
thx
