79-80 full glass hatch
Date: 01/04/2017 04:04 am
Clutch pedal needed
Date: 01/11/2024 06:31 am
6.6.75 carrier
Date: 02/14/2018 06:47 am
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Date: 10/11/2019 11:13 am
Date: 08/26/2018 06:23 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Date: 09/01/2017 07:52 am
  • Online today: 529
  • Guests: 330
  • Total: 330
timing belt cover
Started by lostandfound, March 16, 2006, 09:48:11 AM
lostandfound
1979 2.3l sedan wooohooo
DragonWagon
Yeah, I think the manufacturer is called DIY  :lol:
Might be able to use the existing cover as a guide to fab one using the lower mounting holes and the timing pointer location. I was thinking about doing this on mine, possibly making it out of 1/8" flat aluminum stock. The aluminum is easier to work with than steel, it's light, and shiny!
1976 mpg Wagon. The start of it all.
1977 Cruising Wagon, to be turboed.
1979 glass hatchback. No motor atm.
1980 wagon parts car.
hoots
Isn't the timing pointer on the cover? Is there another type of pointer that would bolt on if the cover is removed?
fast34
You can leave it off, I've seen dozens that way with no adverse effects.
The cover does not need to be on, lots of people run without them, and some just cut the upper part off so they keep the timing mark. The covers do help to keep stuff from getting on the belt, and beteen the belt and the gears. If a small rock or something were to get kicked up and jammed in the belt, it could snap the belt. I know that it is not too likely to happen, but I lost a v-belt that way (had the tell-tale marks on the pulley).
lostandfound
whats the deal with the timing belt cover?? can you leave it off or is that a bad idea i like the way it looks but i dont know if this is a bad idea or not does it make it wear faster??
thanx in advance
lostandfound
