77 Caliper Bolt
Date: 08/21/2018 04:02 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Date: 01/21/2023 04:19 pm
New cam
Date: 01/23/2017 05:11 pm
Date: 06/30/2018 09:48 am
  • Online today: 600
  • Guests: 286
  • Total: 286
Running Rough
Started by PinkPintoRacer, March 02, 2006, 10:13:14 PM
PinkPintoRacer
DTD, I will do that  tonight.  Oil Pressure stays between 60-100 all the time..
dirt track demon
do a compression check cold, then let it warm up til it runs like poop and do another compression check.  Hows the oil pressure (cold, and running like poop).
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
PinkPintoRacer
Thanks PT, that is what I did, had the tach at about 450-550 (X2), and it was sounding good.  After about 20 more min it started to sound rough again.  That is why I was asking about the ground for the dizzy.  I know it is supposed to be where the dizzy contacts the block, but should I put an external one on it, and if so, where on the dizzy
Hello PinkPintoRacer ,
You have to set timing at about 750 rpm.
otherwise the weights will start to move causing centrifugal advance.
You have to let the engine warm has to be off the choke.
PinkPintoRacer
I did that.  It was running about 1400 RPM.  Then I let it run for 20 minutes more, and that is when it started it again.  Could it be as simple as redoing the ground?  There is no ground to the distributor execpt the contact between dizzy and block.
Hello PinkPintoRacer,
you have to set your inital timming after the engine has warmed and you have to use a tacometer so you know what RPM  you are running.
PinkPintoRacer
Ok, got the timing figured out, I am at about 25 degrees advanced, but after about 20 minutes of running, the car starts to act like it has retarded again or missing... any suggestions or ideas.  It is a 74 2300, no vacuum line hooked up...5200 Motorcraft Carb, stock cam, I think....
