Date: 02/28/2024 02:07 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 05/13/2021 05:33 pm
74 pinto
Date: 09/11/2016 06:32 pm
Date: 10/27/2018 03:30 pm
Date: 08/01/2023 06:53 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
  • Online today: 1,185
  • Guests: 642
  • Total: 642
Stacked leafs..
Started by Nevada Pinto, March 02, 2006, 08:40:38 PM
Tude
well i have yet to do it but i have read a little about it. you want to use 2 the same length and have them ().the reason (that i see) is so when it goes up it pushes it back down if it goes down it pushes it back up ....hints the name straight stack
custom fit hammered and bent
pintoches
why do you stack springs?
Ches Lathim
72 Pinto Wagon
78 F150 4x4
87 ford F150
Tude
ok heres a few pics i found on other sites to help with straight stacking leaf springs
here is a tool that is made to help make it a lot safer when building it , i didnt build it im just showing what ive found i have no clue about any of it!
ok now heres some straight stacked leaves ONCE AGAIN NOT MINE. im just showing as a referance
demoiowa89r
we don't stack leafs like ()()() We take some 3/4 ton truck leafs and make a custom pack they don't move.
Proud owner of a 74 pinto sedan. NON-DERBY
a 78 hatch. derby car.
a 73 wagon. derby car.
Tude
i saw on a site last night a very good picture of a set of straight stacked springs in the building
www.democar82.com
look in the general board or general tips and tricks
then the one that says pictures of building tips or something like that
and i think its on the 2nd or 3rd page
Tude
Quote from: hvyeqop69 on June 27, 2006, 05:35:46 PM
I use duct taped springs too but they have seat belt wrapped around the springs first.
very good idea, i have sean tape used a lot, and if you dont use tape make some clamps useing 2 flat peices of metal and 2 bolts each, at the end of each spring
hvyeqop69
Drive the good ones. Derby the rest!
I buy Pinto Spindles.
dirt track demon
 :D  I think i see a new 3M commercial in the making. ;)
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
johnsonracing
Okay,don't laugh,I'm serious.
Have you ever tried duct tape on the springs?It works,and passes inspection at places that don't allow clamping of the springs.Just wrap the springs so that the tape is about 1/2" thick.It will take a couple of rolls ,but I have seen the spings bend right at the end of the tape,so it does work.My current demo car has taped springs.
              Denny
dirt track demon
good call on the clamp them everywhere, or else you will have full spring on dampening and only 2plys on rebound.
The PINTO!!
stang2
Oh yah, don't forget to clamp the leafs in as many place as possible.
stang2
The 2 facing each other don't have to be the same length.  They just can't be way different lengths.  What I do is add one leaf flipped on top of the main (close to the same length) and then after that flip every other one with another leaf added and the bottom two left as normal.  Punch out the center stud and run 3/8" allthread through the middle of all the leafs and tighten them.  For safeties sake after all the leafs start to compress pretty good, I throw them in a press and then tighten them down the remaining.  I don't have any pics as of right now.
dirt track demon
When you stack the leafs,  Dont the 2 that will be facing each other  ()  have to be the same length??  Its been awhile, but I think youll need 4 sets of leafs to make 2 sets.  I could be wrong so dont quote me. Id hate to be called a retard again by someone who cant even spell.
The PINTO!!
CUTWHAT
10,000lsb fork lift leafs work finr for me. :hypno:
Tude
i dont have any pics and ive never done it, it sounds like a pain to do and from what ive heard you flip over every other one and bolt them together like a normal set of springs.
()()()( -somewhat like this and then you bolt them together
its called straight stacking i think
Nevada Pinto
I want to stack a set of leaf springs.. Dose anyone have a picture what they should look like...
