73 rear hatchback glass
Date: 07/06/2017 11:33 am
NOS Sedan decklid
Date: 10/23/2019 11:51 am
1978 pinto grill
Date: 07/24/2018 02:18 pm
New cam
Date: 01/23/2017 05:11 pm
Brake rotors
Date: 03/24/2017 09:02 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Date: 09/01/2017 11:58 am
Date: 04/21/2017 02:03 pm
  • Online today: 553
  • Guests: 214
  • Total: 214
Carb Jets
Started by PinkPintoRacer, February 28, 2006, 11:45:52 AM
dirt track demon
If anyone is interested the tap needed to make holleys jets fit in other carbs  is:  1/4"-32tpi  bottoming tap  I recommend the one from J&L industrial supply company, the one they have for $11 and some change.  The threads on this one go closer to the end than any of the other ones I have looked at.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
PinkPintoRacer
Ok, got it set for 30 deg advanced at 200-2500 rpm and boy it does sound nice.  I ran a wire from the dizzy to a screw on the body too, so that might have helped with the better ground.
I guess next is to get it on the track and play with the jets.... Thanks y'all
dirt track demon
Quote from: PinkPintoRacer on February 28, 2006, 11:45:52 AM
Great Post below about timing.  I was wondering alot of those questions.  But anyway...  Where is a good place to by jets for the motorcraft two barrel carb?  Also, for those who are racing, what jets are you running?  I run on a 1/2 mile track, so I am looking for a good size jet for that size track....
  there is no set recommended jet size for a 1/2 mile track or any size track for that matter.  You need to figure your jets by the test and tune method.  someone might tell you to run 82's someone else might run 78's.   They may have a different cam or different cc heads.  its something you are going to have to figure out once you get it running.
The PINTO!!
PinkPintoRacer
I will add that to things to check tonite after work and see what jets are in there.. I want to check them for clogging anyway
dirt track demon
Quote from: PinkPintoRacer on March 03, 2006, 11:23:52 AM
DTD, what size jet do you use for a 1/2 mile track...
58's, but i run a stock motor(v-6), and the track isn't quite a 1/4 mile. the 58's run a just a little rich. by the way I use a 2150 not a 5200.
The PINTO!!
fast34
PPR, If you are using a 5200 carb, then they use the same jets as a Webber.  The numbers are different, but they will screw right in.
PinkPintoRacer
dirt track demon
We just use a bottoming tap, and tap all of the carbs we use for holley jets.  I dont remember offhand what the tap size is.
The PINTO!!
Tude
i think summit or jegs has a box that you can buy full of diffrent sized jets but i havent got a box yet and cant rember the sizes they have or the price. and i think you should be able to go to most parts stores to pick them up.
custom fit hammered and bent
PinkPintoRacer
