Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 08/09/2018 11:09 am
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Date: 02/14/2019 06:27 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Date: 05/19/2018 04:56 pm
  • Online today: 531
  • Guests: 165
  • Total: 165
Ignition Problems
Started by PinkPintoRacer, February 17, 2006, 06:34:56 PM
PinkPintoRacer
Thanks, I know that part, to fill you in, I blew a coil, I think, on the race track.  I have replaced all that I can replace, exept the dizzy itself.  Tomorrow I am going to pull the timing belt cover and peek under there,
Tude
well if the points arent gaped right then you wont have spark
since it worked fine befor you messed with it i would say that is the problem. did the coil wires (the +/- sides) come undone or swaped around some how the + side should get it from the switch and the - should go to the distributor.
custom fit hammered and bent
PinkPintoRacer
That was it PT.  Now I get spark but no ingiton.. Gonna check timing tommorow..
                                                how much gap on your points?
   sounds like they are not making contact
PinkPintoRacer
Ok, I have changed coil, spark plug wires, rotor, points and condenser on my Pinto, and still no spark.  I get sparks when I short out the points though... Any ideas.........  It is a 74 2300 with single points........
