Date: 11/08/2019 10:01 am
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Date: 03/29/2019 07:20 am
Date: 02/08/2018 02:26 pm
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
Date: 10/31/2018 12:00 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
Date: 07/08/2017 08:25 pm
  • Online today: 367
  • Guests: 295
  • Total: 295
Another carburetor question.
Started by pintoguy76, February 16, 2006, 10:24:39 PM
Fast34, Both of my main jets say 139 on them (not 239). The ones on the top of the body (the air jets) are numberd 195 and 185. I switched the two around both on the main jets and the air jets (for the little trick above that pintony mentioned) even tho the two main jets had the same number (i think somones been messing with jets in this carb). Anyways the jerk is still there, i never messed with timing. It seems to have more power now, but its making that annoying noise that a rice burner car makes with a fart pipe, except it comes from the carb, and its only when the 2nd barrel is open. I also lowered the float a little because it was a bit too high.
Timings been set with the light at two degrees overadvanced from what the sticker says its supposed to be. Altho now, theres no emissions stuff left (egr or air pump which i think it had originally, since i found it in the trunk once i finally got a key made for it) which may and may not effect what the timing should be i dont know. I do know that the engine will idle faster when i mess with the timing more (not sure which direction, but i think its advanced more when it does this)  but slows down again when i put the timing where its supposed to be. Does that mean i should move the timing to where it idles the fastest at, and then slow my idle speed back down?
fast34
The jets in bottom of the bowl are the main jets.  The top ones are the air jets.  You want the bigger of the two main jets in the primary side.  I think 239 is one of the jet numbers in the mains.  The air jets should have the smaller one installed on the primary side.  Sounds wrong but this is how I have allways seen it done.  I think the air jets are 160 and 170.  I may have some numbers mixed up with Webber numbers.  I run a 135 primary main and a 170 air in my Webber on my 20R in my Toyota 4x4.  seems about right, and should work in a 2.3.  Have you checked your ignition timing? I have seen it do this problem too.  May be too far advanced, remember, sometimes have to run more or less than what the book says to make your engine run right.
Tony the jets your talking about are  the brass ones in the top of the body and not the ones in the bottom of the float bowl right? The two in the float bowl look like the same size. Correct me if i am wrong....
whenever the engine is off and the breather is off the carb, i can work the throttle by hand and see the accelerator pump squirt fuel down the throat. Anyways, this jerk/bog happens constantly during acceleration and not just when you first put you foot down, which would be what the accelerator pump would cause an issue with, since it only works momentarily...
Could be that the accell pump diaphram is bad/wrong/installed improperly.
one of the TRICK things to do to the holley 5200 was swap the primary for the 2ndary jet.
Put the big jet in the primary barrel and let me know how it turns out.
I'll bet your happy.
From pintony
If anything it should be overcarbing it. The EGR was deleted and the jets were not changed. Thats how it would work, right? Also, I lost track of which jet goes where when i rebuilt the carb in the past. Tho, since the primary is smaller, the smaller jet should go in the primary side. I think also the float may be a tad too high, but not sure on this. Is it possible maybe the mixture adjustment (in the base of the carb) is too lean (or maybe im getting too much fuel? can that cause this problem?)
Sounds like the carb is starving your engine.
Install a bigger jet in the primary.
From pintony
My car seems to jerk a little on normal acceleration. Even when fully warm. If you push the pedal down  far enough to get the second barrel to open up some, the acceleration becomes nice and smooth again. As long as the 2nd barrel is open its fine but just the first barrel it jerks. Also in the first barrel, pushing the pedal down further it actually feels as tho im actually losing speed (dead spot?) instead of gaining it. Here again tho, once that second barrel starts opening acceleration feels normal. Any idea whats goin on? The top part of the carb has been on and off a few times checkin things out, and i have not used a new gasket any time. Its never torn tho. the gasket still looks good. thanks ahead of time!
