Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 04/27/2018 10:28 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
1976 Pinto
Date: 10/24/2017 02:00 pm
Date: 01/12/2019 10:19 am
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Date: 10/14/2019 08:24 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
  • Online today: 583
  • Guests: 340
  • Total: 340
Vinyl panel restoration!
Started by 73pintogeek, February 08, 2006, 04:51:42 PM
 :text_yb_sorry: forgot to mention.. you want to make sure the panels are clean of any dirt & oils that will prevent the sprays to stick.
There's either two things you can do to make the vinyl trim paint stick... Primer OR a can of spray called Adhasion Promoter. It's soul purpose is to give the paint something to grab on to. I have just used the vinyl paint & for a bit it looks ok, but then starts to flake off after a while. With the adhesion promotor it sticks on a lot better & you wont have to worry about it coming off. I used it on a set of door panels for the sedan & they still look good. & that's with them being tossed about waiting to be installed.
COOL!!!
In what way can you give tips on how to prep. the pannels to spray.
Alcohol rubbs or scotch-brite???
From pintony
Vinyl Paint works great. Here is a shot of my Green 72. I converted all the interior to black and used the Vinyl paint on all the vinyl.
The vinal paint would be great if it works.
I thought about trying on the back side of a pannel just to see.
Maybe use a texture roller while the paint is fresh to make the design back???
from pintony
73pintogeek
Thank`s for the tip`s...I need to specify, the panel`s I`m doing are the molded plastic in the rear of my hatchback over the wheel well`s etc. I have heard that the new vinyl paint`s are pretty dern good from sems...Thank`s again!  :text_yb_tgif:
A bad day workin` on my Pinto is better than a good day at work!
pintoman
I removed all the pastic panels from my Rallye.Then i bought 10 yards of vinyl [the good stuff],with a little luck i covered all the panels with the vinyl.It was not,t easy but worth it.
skrach
73pintogeek
Hey all...I`m going to start next on restoring the vinyl panel`s on my Runabout ,it has scratches and the usual sun-fade...doe`s anyone make a good vinyl paint these day`s? Or is there a better way to accomplish this...just fishin` for some idea`s... :idea:
Thank`s... Da Geek
