Date: 09/05/2018 06:30 pm
door sills
Date: 03/14/2020 03:20 pm
Oddsnends
Date: 12/20/2016 10:52 am
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Date: 04/10/2017 07:30 pm
Date: 12/10/2017 01:14 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
  • Online today: 600
will a stock 2.3 pinto 4-speed hold up in a turbo application
Started by traksyde, November 19, 2003, 02:27:28 PM
Pinturbo
I'm wondering if the clutch fork out of my cable bell housing will fit in the thunderbird hydraulic bell housing.  Did you ever try that?
Kurt
SVOwagon
Well I'm sure someone will jump on my case again, but...this is how...I....did it. I reused the Pinto cable and got a bellhousing from a mid 80's mustang that came with a cable clutch set-up. I reused the Thunderbird pressure plate, clutch and flywheel.
SVOwagon
80 2.3 EFI Turbo Pinto Squire Wagon
91 Mustang LX 5.0 (93 Cobra clone project)
82 Mustang GT (built 460)
89 Mustang LX coupe (built 302)
83 Ranger
http://www.cardomain.com/ride/2167062
Pinturbo
I am going to swap turbo 2.3 into my Pinto this winter. I want to swap the t-5 first and clear up those issues first.  The stock setup is a 4 speed stick and looks almost identical flywheel, bolt pattern on bell housing, and so on.  ONe obvious difference is the clutch accuation. the T-bird that this came out of had a hydraulic clutch.  So here is the question...for those of you who have already done the swap, did you keep your cable clutch or did you adopt the hydraulic clutch and what was needed to make it work in either case?
Kurt
ok mine's got a cooler on it, the lines are on the pass. side. the gasket set i bought for the filter was a c-4 and the modulator was set for boost?!?!
P.S. i was TOLD by the guy i got it from it came from a mutual friend's 83-84 cougar XR-7
SVOwagon
60 mile trip everyday     GO..with the T5!! I'm running a T5 in my Pinto and with the 3.97 first gear I'm able to have 3.00 gears out back. Still get good performance and good gas mileage because of the over drive.
One more thing..turbo cougars never came with c4s...either it's not a c4, or someone put one in it. Could be a c3.
  SVOwagon
83 Ranger
Ok cool my c-4 is out of a Turbo Cougar, anyone need it?(kidding) it's too long by 1/2" (the yoke bottoms in the tailshaft) so the AOD may be the ticket for a mild N/A 2.3
remember mine's a daily driver and i've got a 30mi one way drive. I'll sacrifice top performance for reliability, and comfort.
The AOD will be longer, It will not last long behind a healthy 2.3 turbo. Get one from a Turbo coupe and have it built if your gonna put the power to it!
Ok , i have access to an AOD 4speed auto from a fox Stang. how much difference is there in the size from a c-4 auto?
SVOwagon
83 Ranger
Killer74
I ran my stock 4 speed for a LONG time and no problems. 18psi and 100 hp NOS on drag radials with a MEAN clutch set-up.
*74 Turbo 2.3 Pinto
*77 351w Turbo Pinto (still in the works)
SVOwagon
The stock 4 speed might...might hold up to a "stock" turbo motor. I think you should go with the 5 speed right away. That way you won't have that little voice in the back of your head that is wondering if the trans is going to hold or not. Plus if you plan on make more horse power, the t5 is definitely the way to go. If the motor you are getting doesn't have a t5 on it, you can get one from a mustang from about 84-93. Or even a Ranger of about the same years.
SVOwagon
83 Ranger
 You dont hear of guys blowing up stock 4 speed trans to much. If you allready have a T5 I'D got that rout if any thing for the over drive.
traksyde
i am debating on building a 2.3 turbo pinto-will a stock pinto unit hold up?I am trying to decide on it or a 5.0 setup i already have.
