Date: 10/25/2019 04:05 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
77 pinto
Date: 08/22/2017 06:31 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 03/13/2021 12:57 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
  • Online today: 584
  • Guests: 491
  • Total: 491
hatchback to sadan
Started by LincoPinto, January 20, 2006, 05:28:11 PM
LincoPinto
I have had both, but it was a long time ago for the sedan. I would imagine that IF you had all the parts, AND/OR you had the ability to do some cutting and welding it could be done. Most likely you would need a donor car to get all the parts: rear window, seals, seat back, interior panels, lid, hinges, springs, latch, head liner, lower window frame/trunk lid frame.....   The tail light panel and the roof MIGHT be different too, but at a minimum you will have to fill in the hatch hinge holes in the roof. You might be able to fab up some of the parts if you need to. If you have a donor car, give both cars a good look and see what is different.
Almost anything can be done with enough time and money. In the long run, and IF your car does not have any sentimental value, it might just be cheaper and easier to just get a sedan.
Let us know how it goes,
LincoPinto
Can you convert a hatchback to a sadan? If so how?
Thanks
