77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Date: 02/28/2018 09:18 am
Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 06/25/2021 12:59 am
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 08/03/2018 09:19 am
Date: 08/13/2021 10:39 am
Clutch Fork
Date: 03/31/2018 09:12 pm
Date: 10/01/2020 02:00 pm
  • Online today: 535
  • Guests: 344
  • Total: 344
EGR
Started by lostandfound, January 18, 2006, 01:02:09 AM
If you leave it open you will have an BIG exhaust/vacuum leak. Just a simple flat cover and some gasket material will do.
As far as the fuel/air, it won't be off by much, and it will be rich. A performance air filter might balance it out.
lostandfound
can i leave the egr holes unblocked on the manifold will it still work? or if i have to block the holes, how do i do it so i dont mess up my fuel air ratio?
1979 2.3l sedan wooohooo
Mornblade
In this state they do test old cars, but they are held to emissions standards of the time when they were built.  Also, Illinois only tests in high population areas.  So if you live in a rural area, they won't test your cars.
For what it's worth, I removed the EGR from my motorcycle and noticed very little extra power, but my gas milege went up, and the bike stopped backfiring on deceleration.
Ummm.... Yea, to both.
Cold air can make you more power, that's why people get rid of egr's, as well as the breather to intake line.
Depending on your state, it might cause a problem. My state has no testing for cars older than 25. This is not to say that it is legal to remove it. The egr routes   exhaust gas back into the intake and re-burns some of the un-burnt fuel. Without it, the car puts out more hydrocarbons, and might fail a smog test. If all other controls are working fine you might be ok.
Keep in mind that the carb. is set-up for the extra air, so when you block the egr it can mess your fuel-air ratio. Blocking the egr will not give you enough extra power that you will feel, but every little bit will add up.
lostandfound
is less hot air a good thing and also will this effect emmisions?
On my racecar I just removed it and made a plate to go over the hole. EGR's don't open at idle, or a full throttle. In thery, if it is bolcked off you will get less hot air into the engine to burn. Also, I rejetted my carb and a few other things.
lostandfound
hello i was wondering what would it take to remove the egr valve and have my engine run correctly or if this can even be done
i have a 79 pinto with a 2.3 help appreciated
thanks lostandfound
