Date: 09/15/2019 12:38 pm
KYB shocks
Date: 02/08/2017 07:09 pm
Date: 11/12/2020 08:28 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
Date: 03/30/2021 12:29 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 10/04/2019 08:43 pm
SVO SWAP
Date: 03/15/2018 03:12 am
  • Online today: 481
  • Guests: 154
  • Total: 154
Winter Projects
Started by gpinto2, November 16, 2003, 04:15:33 PM
yup, you'll be right into the boost off idle....but you'll fall flat on the top end with a couple of those. I'd stick with the T3's but get a couple of .82 turbine (hot side) housings from older buick V6 turbos.
Killer74
Quote from: 78pinto on December 24, 2003, 12:37:19 AM
Hey Killer, what turbo you going to run on that 408? I was going to do a twinturbo on mine, using two T3's  .48 hot side and .60 compressor side, but changed my mind.
Those are the same turbos I have but I know they are gonna be WAY too small. I'm going to change over to a big single after I get the rest of the car lined out.
*74 Turbo 2.3 Pinto
*77 351w Turbo Pinto (still in the works)
 A look at the jets pointing toward the turbo from inside the intake plenum.
 Top view ( not complete) but you get the picture.
I was playing with the intake plenum on my Black Pangra and......well what do ya know, look what just happened to bolt on the bottom ( out of sight )
pintojoe
Finished installing header and 2.25 exhaust with flowmaster. Next to do is the front sway bar, check the balance and install new rear springs and lowering blocks, get some sticky tires and go solo 2  in 2004
1973 Pinto runabout, 2000cc,4spd.
bday
We are doing extensive flow bench work on a fresh cylinder head. Looking for at least 1 to 2 tenths in the 1/4  mi.
Killer74
I'm gonna be pulling the 302 and S-rod out of my 77 and slipping in a turbo 408 W and a C-4.
*74 Turbo 2.3 Pinto
I ordered the front end rebuild kit, and the tubular upper a arms (the lowers would hit my headers so i did not get them) upper engine gastet set is also on the way. The upper intake and headers will be sent off after Christmas to be ceramic coated (shiny chrome like finish) and my new Windsor Sr. heads will be ported and and assembled after Christmas as well....i will be sooo busy this spring!
my winter project: I'll be getting my new intake (351 lightning lower '93 cobra upper) ready to put on, along with a new 75mm throttle body, 76mm mass air meter. I'm also VERY close to having a nice set of World Products Windsor Sr. heads to put on also (2.02 and 1.60 valves) I'll be in the elevens....or i'll be broke tryin ;D   I'll also be wiring up a factory Ford CD player and redoing the front suspension. i'm gonna be busy. :'(
Quote from: 78pinto on November 17, 2003, 07:44:24 PM
Hey Glassman, what suspension kit did you buy and what all comes with it  (upper a arms ect..)
I got this one http://www.p-s-t.com/ford/fofekpg.html . I have to reuse my A arms. I had to replace them on our Grand Marquis so this isnt the first time.  :)  I learned a lot when I did the GM's. Like measure the distance between the bushings BEFORE removing them from the arm. ::)  Looks like the Pinto will be easier. Oh yeah I forgot I rebuilt the front end on a 65 Falcon I had. That kit came with the arms. I have used a PST kit on the Falcon and were happy with the product and service.
I intend to finish redoing my interior. i have all the materials finally, and this winter i should have time to gut my car (i accidentally typed cat,, is that wrong??LOL)and fix the known rust holes in the floor.
Hopefully I'l get to start on the bodywork too.
I'm in the process of drawing up "euro" taillights too
$$ permitting i intend to get those done, and displayed to you in the next month or so
Ive been purchasing parts for my Pinto project for a while now. Soon I will start replacing and detailing parts. So far I have an 88 TurboCoupe engine, harness and comp. (LB3), C-4 bellhousing, Moog front coil springs, Hiedts 2" drop spindles, Volvo front mount intercooler, trans. fluid cooler, P.S.T. polygraghite front bushings and ball joints. I also have a rebuilt rack and pinnion. Still have plenty to get.
I have to do the Escort tail light swap also.
I have about 6 months to do all this. First will be the front suspension. Then, the engine and trans swap. Then, the rearend rebuild and swap (8"). The body work will be last.
79Minto
I'm picking up the Mustang parts car next week. So I will be pulling the motor and rims on that doing a Refresh, Bearings,GAskets Get the Crank Spun Etc. Putting the 1st Gen Edelbrock Torker ,Holley. Comp Cam and Lifters, Pete JAckson Gear Drive. Pistons if I win the auction.   Then I will have to Fix the Driver side Floorboard. and cut and weld some other parts.
gpinto2
So who is working on their Pinto this winter and what do you have planned for the project?
1972 Pinto 410,C-4
