Date: 07/04/2022 07:55 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Electrical
Date: 03/29/2017 11:37 am
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 01/04/2017 04:07 am
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Squire trim
Date: 03/28/2018 10:11 am
Date: 03/23/2018 09:23 pm
  • Online today: 600
  • Guests: 382
  • Total: 382
lifter removal
Started by lostandfound, December 20, 2005, 02:25:22 AM
The easy way that I do it is with a grease gun. Use a pointed fitting and inject grease into the holes next to each lifter. They will pop right out. Remove the grease and install new lifters. I have had some that you could lift the car with(broke apart with the vise-grip), but they just slide out with the grease, amazing.
johnsonracing
using a visegrip clamped on the lifter,( down from the top pivot area to prevent damage)tap on the bottom of visegrip with hammer to force the lifter up and out.You should buy a new set if you are doing any motor freshening.Cheap,should be able to get a set for under $40.00 at the right auto parts store.
   If you are putting in a new cam you have to buy new cam followers.This a must because the two parts have to wear-in together.
:o :o
lostandfound
i have removed the camshaft and all of the parts on the cylinder head but the lifters will not budge i can lift the cylinder head up  by picking it up by  the lifter
1979 2.3l sedan wooohooo
