Date: 07/17/2018 09:22 pm
Date: 03/30/2021 12:29 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 08/26/2018 06:23 pm
Date: 02/14/2019 06:27 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Electrical
Date: 03/29/2017 11:37 am
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 02/18/2017 04:47 pm
  • Online today: 488
  • Guests: 475
  • Total: 475
How do I fix RUST
Started by pintoman2009, December 07, 2005, 05:07:08 PM
Click here for my experience with POR-15. http://www.fordpinto.com/index.php?option=com_smf&Itemid=26&topic=589.0
I think POR-!% is worth the money, a little goes a long way.
Ive seen at least one new product that claims to work better than POR-15. I cant remember the name.
skrach
there are alot of different ways you can approach this..  if the rust is too bad, then you will have to either replace the area with a donor piece, a piece from another car..  or you can simply weld in another piece of sheet metal.  if its mild rust.. then i would reccomend using a product called rust - mort. and it basically stops the rust in its tracks.. it is made by a company called SEM they make a bunch of really cool seam sealers. which would be another step you might want to take after stopping the rust. to seal off any rust.  but here is the link to the rust mort. http://www.sjdiscounttools.com/sem69508.html
um there is another product but i heard its pretty pricey.. where sem isn't all that pricey.. its called POR-15  here is the link to that. http://www.por15.com/
hope this helps..  if your on a low budget lol use coca-cola it works but not as good as these companies
pintoman2009
How do I fix rust and what do I do
Posted By the 1980 ford pinto kid
