Date: 03/15/2023 02:16 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 08/13/2021 10:39 am
free transmissions
Date: 11/28/2019 10:21 am
Interior Parts
Date: 08/07/2017 03:59 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Date: 05/13/2021 05:29 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
  • Online today: 481
  • Guests: 370
  • Total: 370
2.0 to 2.3 for '74
Started by bob55, December 06, 2005, 10:26:47 PM
72pair
Another interesting note for '74. The '74 2000cc block I recently pulled from a junkyard automatic car had stepped dowels. I assumed they were factory as this car looked very original. I went through the whole rebuild process and did not notice until my '72 bell would not fit. Luckily, I still had the cracked block with 2000 dowels. Now I have a stepped set for 2.3/C-4 combo if my clutch foot ever gets tired! JT :laugh:
Bob55, and all
This swap is one of two regarding the 2.3 into 74 and earlier. The 74 was a new transitional chassis in the engine compartment, and front suspension. The motor mount supports for a 2.3l are to allow for a change in the entire dimension of the width of the front frame and crossmember that was added as the car was made with both engines in 74.
We pre 74 owners who wish to add a 2.3 in place of a 2.0  have to acquire the "special" mounts from a 74 2.3.
There may be a VIN and MFR date issue to find when the pieces were first used.
I'm sure someone knows the correct pieces in this forum.
Dick_Nixon
thank you, that thread in enlightening.  :read:
Pinto. Leaves you with a warm feeling.
http://www.fordpinto.com/smf/index.php/topic,12068.0.html try this i looked for you ... Edit: wow i misread this big time i thought you wanted to go from a 2.3 to a 2.0 hehe im not sure what oyu have to do there... My best Guess is to keep askin Im sure some of our knowledge base will have an answer for you..
Dick_Nixon
I haven't been having that much luck with the search. Maybe I'm just using the wrong words.
There was a thread conserning this very thing started by another member you might want to search the swap and see what is said there. I know that you need Stepped dowels for the transmission.
Dick_Nixon
I'd also like to know the answer to this question. I'd appreciate it and you'd be helping a dying Pinto.  :)
bob55
What's required to put a 2.3 in place of the 2.0 in a '74 with C4?  Is it a weld-in for frame mounts?  Bellhousing?  Email at bob_10@comcast.net
In a quandry......
