72 Pinto parts
Date: 11/14/2019 10:46 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 06/22/2017 07:19 am
Bumper Guards
Date: 03/28/2017 09:27 pm
Bell housing
Date: 08/23/2017 05:41 am
Date: 12/10/2016 04:11 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
  • Online today: 642
  • Guests: 554
  • Total: 554
74 pinto water leak heater inlet no a/c
Started by dompinto, November 03, 2003, 11:55:00 PM
0 Members and 3 Guests are viewing this topic.
dompinto
just took out the heater the air inlet was cirled with rust/leaves and found several holes in the steel, so sealing and fixing the rust should do ,alot od calking.
dompinto
Hello,thanks for the welcome its a 74 with 33 k miles white /tan 2.0 4 speed. I thinkd there was alot of dirt under the cowelmaybe it built up over the hole to make it ct like a man hole,well wee later ,Frank.
i'm sorry i can't help you....i have no heater box! Someone will answer your question. Welcome to the site!   Jeff
dompinto
hello,just bought a 74 pinto ,no a/c has water comming in  to the heater comp /vent through the outside air hole,.the heater was done in 91,is something missing ? the compression gasket is there but getting wet, acting like a catch basen,dont know what to do to stop it HELP,should I close up the outside air inlet? comming out tommorow,thanks .....
