pinto floor mats??
Date: 01/11/2017 07:27 am
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Date: 03/30/2021 12:29 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Date: 12/10/2016 04:11 pm
Windshield
Date: 01/15/2022 09:31 pm
Date: 02/28/2018 09:18 am
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
  • Online today: 238
  • Guests: 183
  • Total: 183
carburator rebuild
Started by lostandfound, November 22, 2005, 09:34:44 AM
bluefordpinto
if you end up tearing the gaskets you will need the re-build kit, like bill has said. however, there were two different types of carbs used on the pintos (assuming your using a 4-cyl). one was a really popular carb that is easily available on the counter from auto zone, the other not so popular will be extremely hard to find. all i can say is, good luck, be carefull and check e-bay often if you break one of them gaskets. have fun! ;D
GET 'ER DONE!!!!!!
billnall
When you take it apart be careful not to break the gaskets.
If the gaskets break and tear you will need a kit.
Get 1 or 2 cans of spray carb cleaner and clean it out use the straw that comes with the can and spray it through
all the holes in the carb.
I have cleaned carbs like this.
Ford Parts Man
80bobcat
Hi ..this is what I did.....to just about anything that needed cleaning including the carb....soak it in a pail of varsol(paint thinner) whichever is cheapest..overnight..you will surprised at the gunk that`ll come off..I didn`t have trouble afterwards but to be honest I started the turbo project shortly after. Hope this helps
Look Officer..it`s a Pinto would YOU stop short?
lostandfound
i opened up my carb the other day and i discovered about an half inch of sludge in the bottem of the bowl is there anyway to clean out my carb without buying a rebuild kit?? rebuild kits are kinda spendy for me im on a limited budget
thanks for all the help
lostandfound
1979 2.3l sedan wooohooo
