Date: 02/05/2017 09:45 am
Date: 02/14/2018 01:34 am
73 Runabout
Date: 11/20/2017 03:19 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
Date: 03/27/2017 10:07 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Pinto Wagon
Date: 05/25/2018 01:50 pm
Date: 10/01/2020 02:00 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
  • Online today: 394
  • Guests: 327
  • Total: 327
pinto suspension shared with others??
Started by firemedic1070, November 03, 2003, 12:26:31 PM
pintojoe
A'm thinking 71-73 same, 74 and up diffrent think lower arm longer and upper at chassis mount bolt spacing. But do know 74 lower balljoints fit with a little grinding of the strut rod bolt holes that go through the lower arm.
1973 Pinto runabout, 2000cc,4spd.
reflexr
What are the diffs between 71 and 74+ susp.? Does anything interchange?
Joey
06 Ford Mustang 4.0 T5
thats a great site for suspension parts!! Its now in my favorites!  Thanks,   Jeff
fatheadinc
dont know what parts your after or if you want new a arms stamped or tubular or spindles for pintos and stang 2s
yall might try speedwaymotors.com ....
pinto brain child
74 runabout butcherd bbf project
victimized 71 sedan
No slam taken, i shoulda specified the early Capris. I wasn't sure they were the same tho
8upwithpinto
The Capri did not share front suspention w/Pinto. I've had 4 Capris and they all had struts up front. 71 to 77 capris were the same. I'm not trying to slam anyone , just saving all time in the bone yard.
80 Pinto
91 5.0 LX
02 Mustang GT
01 ZRX1200R
I can't speak for the Tanus or Cortina (the Cortina design is 4-5years older than the Pinto, and WAS imported to the USA) the german Capri has the same design as the Pinto, but i don't think they're the same thing. The 'StangII is absolutely identical tho.
Interesting side note, the cortina, and Pinto were supposed to have a prototype V4 engine. I think it was a 289 cut in half!!!!!
I think the only suspension sharing was with the Mustang II.  Iv'e seen cortinas here....not in good shape or for a long time now, but i don't think they are the same.  What about the German Capri?
8upwithpinto
Not that I'm a pro at anything but, I'd say that would be difficult to tell. Can't speak for our Canadian frends but, I don't think(correct me if I'm wrong please) those cars made it to the U.S.A.
80 Pinto
91 5.0 LX
02 Mustang GT
01 ZRX1200R
firemedic1070
Does anyone know if the pinto shared its front suspension with the ford cortina or the taunus. Thanks
