sport steering wheeel
Date: 10/01/2020 10:58 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 10/31/2018 12:00 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Date: 10/25/2019 03:30 pm
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Date: 02/05/2017 09:45 am
  • Online today: 529
  • Guests: 409
  • Total: 409
AOD for 2.8L V6
Started by gentlegiant, November 15, 2005, 01:01:51 PM
bluefordpinto
that would explain the shitty shifting after the swap. i was stumped by it.  ???
GET 'ER DONE!!!!!!
bigh4th
The "AOD" trans your talking about is an A4LD trans.  One from any 2.8 (late 84-85 ranger/bronco II and 86 Aerostar) or any 2.9 ranger/bronco II will fit, but it will hate you for doing it.  The later A4lds were partialy computer controlled and ALL a4ld's have an electric lock-up converter.
But...be forwarned, The a4ld is based off the the not-so stellar to begin with c3 3 speed auto thats behind your 2.8 now.  Beleive it or not, ford somehow made the thing worse when they added a 4th gear to it.  A4ld's are junk and your money would be better spent rebuilding your c3 or replacing it.   To give you an idea of how bad they are,  There are plenty of rangers/bronco II's/Explorers in junkyards with something around 150,000 miles on them because the trans has crapped out.   They either eat the friction material off the clutches or blow the front seal.   The front seal isn't a simple fix because some nutjob at ford decided the bellhousing and trans case should be align-bored as an assembly, so if you remove the bellhousing it can throw the centerline off and a replacement bellhousing has to be either shimmed or re-bored and have a spacer pressed into it.
I personaly had an a4ld puke its guts out on the interstate at 160,000 miles in a 90 bronco II.   Front seal blew.  Was quoted a rediculous price for a rebuild everywhere I called.
Stay away from it.
-Harry
bluefordpinto
i had a buddy bolt a AOD from an '88 ranger with a 2.9l to his grandpas '98 ranger with a 3.0l so maybe that should help you out, it may bolt right in with "minor" modifications (I.E. a whack or two here and there, or cut out and install some new sheet metal.) but hope that helps you.
GET 'ER DONE!!!!!!
gentlegiant
I'm interested in possibly mating an AOD trans to a 2.8L.  What are my options?  Best/easiest?
