Date: 03/05/2017 03:27 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
Date: 05/19/2018 04:56 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Date: 08/26/2018 06:35 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Date: 12/31/2017 11:14 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
  • Online today: 525
  • Guests: 198
  • Total: 198
Intermittant wiper install, having problems
Started by TIGGER, November 02, 2003, 01:22:59 PM
I am trying to install an intermittant wiper setup into my 73 Pinto. The setup came out of a 77 Pinto Wagon. The problem I have is the wiper motor will not reset to the unused position when the switch is turned off. I think it did the same thing with the original switch. I will reinstall it tomorrow and see. Also the intermittant does not work. When switched on intermittant, the wipers run constant and are on low. I have the switch ground, grounded but the relay box and switch are hanging. Does the box need to be grounded? Do you think I have a problem with the motor? Do I need to change it to a later model one? I remember reading some where that the wiper motors were different between the early 70's and late 70's cars. I have also read that this is a simple swap for the 69-73 Mustangs? Any help would be appreciated.
