hood for a 79-80
Date: 11/30/2018 10:55 pm
windshield
Date: 04/14/2018 08:53 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Date: 08/09/2018 07:49 am
door sills
Date: 03/14/2020 03:20 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 08/13/2017 02:01 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 12/09/2018 06:59 am
  • Online today: 489
  • Guests: 175
  • Total: 175
gas tank removal
Started by lostandfound, November 09, 2005, 09:21:49 AM
71hotrodpinto
hey there wasnt sure if you needed the gas tank sheild but heres a NOS one on ebay + a Nos filler tube. Be forwarned though theres no hardware for the shield.
http://cgi.ebay.com/ebaymotors/71-72-Pinto-Fuel-Tank-Recall-Kit_W0QQitemZ8019043007QQcategoryZ33556QQrdZ1QQcmdZViewItem
billnall
Part number correction for above post E1AZ9072B
Ford Parts Man
billnall
The grommet where the neck fits into the tank is still avaliable from your local Ford Dealer.
73-80 part# E1AZ9072A
Ford Parts Man
Jinxter
As far as the fuel tank recall goes, your tank should have a plastic shield installed under the tank straps to allow it to slide over the axle/diff in case of a rear-ender.  That would be factory installed.  There are also NO bolts protruding towards the rear that could rip the tank open, and your diff has rounded 'corners' instead of the earlier semi-circular cutouts with sharp corners.
If you haven't already removed it, take care with the filler neck seal.  If it's in good condition, coat it and the filler neck with some Vaseline prior to re-installation.  They're not easy items to locate.
Beat it to fit, paint it to match...
bluefordpinto
i just recently picked up a '73 hatch-back and the guy completely wrapped the tank in 1/4" alluminium. pretty good idea, except for i aint scared, and i dont need the extra 1/2lb of weight. so i cut it down, big time, anybody want some alluminium? lol!!!!  ;D :D
GET 'ER DONE!!!!!!
billnall
Most radiator shops will clean out a gas tank.
Ford Parts Man
MattG
Does Anybody know of any places in TX that will boil out your gas tank. I live in Huntsville, But I love to drive so tell me!
74 Runabout 2.3L
STpinto
You really should inspect the seal where the sending unit goes in and also  the filler neck seal for any cracks or suspicious appearance. I think those seals are still available at some radiator shops. While you have it out, you should service your gas lines and have the tank boiled out to remove scale and sediment. Don't take any chances here, and when you re-install the tank, see if you can put some extra sheet metal on the rear axle housing, where there are some projections that can rip hour tank open in the event of rear end collision. Just look for anything that could perforate the tank if it is pushed forward, and see if you can do   any modification that can make the tank protected. Good luck
Keep on Keepin on
lostandfound
i am about to remove my gas tank out of my 79 pinto is there any thing i should be aware of and also will i have to buy any new seal to re-install it?
thanks
1979 2.3l sedan wooohooo
