Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 11/05/2020 06:32 pm
Date: 11/29/2018 10:26 am
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Date: 09/15/2019 12:38 pm
Date: 03/17/2019 10:15 pm
Date: 03/16/2017 10:00 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
  • Online today: 533
  • Users: 1
  • Guests: 490
  • Total: 491
help!!
Started by 79pinto302, October 30, 2005, 05:17:30 PM
gpinto2
I would take as much as possible,Take your whole drivetrain(motor,trans.driveshaft and rearend)motor mounts,radiator,ignition unless you plan on upgrading that.If you end up not needing some parts you can always sell them here.You have the ultimate donor car so it will be a pretty simple swap for you.
1972 Pinto 410,C-4
skrach
id say keep the rear end.. depending on what gears it has.
What trans is behind it?
79pinto302
i have a 76 mustang II with a 302 what should i take off of it to convert my 1979 pinto to a V8 ???
