Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 07/30/2020 11:45 am
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Date: 02/28/2018 09:33 am
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 09/26/2019 05:31 pm
  • Online today: 292
  • Guests: 274
  • Total: 274
2.3 engine timing
Started by pintoperformance, October 31, 2003, 09:23:48 PM
PINTO1
To Mike: In regard to wiring schematic for your Pinto you can get the following publication: Haynes - Ford Pinto & Mercury Bobcat,  All Models 1975 thru 1980  140 cu in (2.3 liter), 170 cu in (2.8 liter).  Owners Workshop Manual.  Chapter 10 is loaded with pages by year models.  I have used this guide in installing the wiring harness from a 79 Pinto into a Jaguar XK120 specialty car.  It wasn't easy!
darrel1
Ebay has some electrical schematics available
ebay motors then seach under pinto
darrel
pintoperformance
I have a 1978 Ford Pinto Panel Wagon-it has a 2.3 4 cylinder engine.
Recently I had to have a new camshaft installed and when I got the head back from the machine shop I reinstalled the head and tried to start the engine it would not start...
I have tried to reset the timing of the crank and the camshaft to #1 Piston TDC on the compression stroke--still will not start (also set the distributor to #1 plug--
I installed a new voltage regulator, a new starter relay,a new distributor,a new spark box still will not fire--
I am using an Accel High output coil (no balist) would that make a difference also I am using the distributor that has one vaccum instead of the two vaccum that the 1978 called for---would that make a difference?? reason I am using that distributor is that I could not find a rebuilt one at any of the aftermarket parts stores.
Also does anyone have a wiring diagram for the 78 Pinto--color coded wiring diagram would be great--I would gladly pay for a copy if someone has one they can mail me--I have tired to find one but even the library does not have a listing for the Pinto....
thanks,
click here to see Pinto Street Machines PINTO OF THE MONTH
http://pintoperformance.tripod.com/pintoperformancedrivein
and if you are interested in joing a Ford Pinto Street Machine National Car club (has over 400 members nationwide)
http://autos.groups.yahoo.com/group/fordpintostreetmachines
paste into your search engine or just time in ford pinto street machines--that should get your there
