Pinto Wagon
Date: 05/25/2018 01:50 pm
77 pinto
Date: 08/22/2017 06:31 pm
Date: 12/24/2016 04:13 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Wheel cap
Date: 04/25/2022 11:21 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Pinto Wagon
  • Online today: 394
  • Guests: 310
  • Total: 310
V8 motor swap will T5 fit, also what rearend fits?
Started by pinto bean, October 28, 2003, 09:20:54 PM
8.8 is very close. My 9 inch is 51 inches i think and a mustang 8.8 is 52 inches, but i'm not 100% sure. Tom and i were going to do the 8.8 in that green '78 .....instead my father inlaw is buying it.
Killer74
the T-5 I put in my turbo 2.3 used the same mount as the later T-4.
The 8" rear from a Mustang II is a direct swap, the 9" or 8.8" will probably be too wide and require a lot of work.
*74 Turbo 2.3 Pinto
*77 351w Turbo Pinto (still in the works)
pinto bean
I have a T5 out of a 91 mustang that was behind a V8 and I am intersted if anyone has done this or is the T5 to long. I know that the T4 is basically the same transmission but it was behind the 4cyl and I do not know if the V8 moves the transmission back further. Also does anyone know if there is a rearend out of a later model mustang that is the right with, I know that I will have to put spring perches on but that is not a problem. I would like an 8.8 rearend or if possible a 9 inch this only because I have some parts left over from some mustang projects. I would prefer the 9 inch because I have more parts for it.  I am new to pintos so please be patient.
