Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Date: 09/15/2019 12:28 pm
Date: 07/20/2017 01:23 am
Date: 06/24/2020 06:12 am
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Date: 03/17/2019 03:57 am
Rear Bumper
Date: 07/26/2021 01:08 pm
  • Online today: 445
  • Guests: 277
  • Total: 277
Trans swap questions...
Started by 8upwithpinto, October 28, 2003, 04:25:53 PM
CHEAPRACER
Geeze, I just realised we are posting on a 9 month old question ???
CHEAPRACER
NOOO! Don't waste your time cutting a driveshaft. Using a T-5 with a stock 79 thru early 90 something Mustang driveshaft fits perfect. I used a Motorsport aluminum shaft with a hibrid u-joint on the rear from Autozone (front was large style and back mated to an 8 inch rear small style yoke) And couldn't fit any better.
Quote from: 8upwithpinto on October 28, 2003, 04:25:53 PM
Does anyone know if a Mustang II petal cluster will work ina Pinto? Don't have many doner Pintos around here. I can find more mustang IIs laying dead close by. Any suggestions?
I compared the two earlier this year.  The Mustang II pedals have a different curvature than the Pinto.  It was very close though, so they might still work.  I am pretty sure you will only have to change the pedals.  You shouldn't have to swap the whole bracket (PITA).  My 79 hatchback, which was a factory AT car, had all the holes punched in the bracket to install the clutch assembly.  3 bolts and you are done.
straw boss
Quote from: 8upwithpinto on October 29, 2003, 02:37:29 PM
when installing a t5 trans; Does anyone know if the driveshaft has to be cut or can I just swap out the front yolk/snout?
The original four speed and bellhousing measure about 30-1/4" long (front of bellhousing to output shaft seal).  A T5 and bellhousing measures about 31-1/2" long, so yes, you will have to cut the driveshaft if you are replacing a four speed with the T5.
kmayle
i can't promise it, but a friend of mine did a 302/T5 swap in his 75 pinto.  He used a driveshaft out of a mustang II he claims.  He didn't use the stock drive shaft for the car.
don't know if it was a manual or auto mustang II.  but... i drove in the car personally so well, thats what he claimed.
Needs:
Inner Passenger Splash Shield for 77, center grill/radiator brace, A front mount working intercooler setup
77 Turbo Pinto 19k - I hear you could get these as an option upgrade to the SVO?
8upwithpinto
Also, not that I'm doubting anyone but, when installing a t5 trans; Does anyone know if the driveshaft has to be cut or can I just swap out the front yolk/snout?
80 Pinto
91 5.0 LX
02 Mustang GT
01 ZRX1200R
8upwithpinto
80 Pinto
91 5.0 LX
02 Mustang GT
01 ZRX1200R
