Date: 09/26/2019 05:31 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 03/06/2017 01:24 am
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
New cam
Date: 01/23/2017 05:11 pm
Date: 01/10/2022 03:41 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 08/08/2017 01:44 pm
  • Online today: 600
  • Guests: 384
  • Total: 384
2.3 question
Started by fwpinto, October 05, 2005, 07:29:36 AM
pintowgn73
on those engines they replaced the dist. with a camshaft pos. sensor and syncro shaft which is basicly the bottom half of a dist with the sensor on the top. take that out and a dist. will slide right in. same thing on the 5.0l in explorers and 3.0l ohv in taurus'. the engines that never used a dist don't have any way to install one but on the engines that did they used that shaft and sensor. here is a pic of what I'm talking about.
pintowgn73
the dist. will slip right is and should work fine. I think that the newer 2.3's had one of the intake bolts in a different location. nothing a little *cough*silicone*cough* won't fix...
fwpinto
I am just getting into ford pintos.I have noticed that the pinto came with a 2.3 engine.Can a later model computer controled 2.3 be converted back to points and carbureator?I know a man who has a 1989 ranger with 4cyl engine.Was wondering if it`s engine could be converted to points distributor and carb.thanks
