Date: 01/18/2017 05:35 pm
Pinto drive train
Date: 06/29/2018 08:32 am
1972 pinto grill
Date: 02/27/2018 12:13 am
Wheel cap
Date: 04/25/2022 11:21 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 12/31/2017 09:03 pm
convert to stick
Date: 05/19/2018 09:26 pm
  • Online today: 489
  • Guests: 288
  • Total: 288
Help with old school hot rod Pinto
Started by jbpinto, October 03, 2005, 12:22:31 AM
71hotrodpinto
hello there.
Theres only one real issue besides the missing parts . The valve body is setup for a engine that has allot more torque than the little 2.0 .The shift points will be wrong and it will not run correctly. However it wont hurt anything. Just wont be like it should.
You will need the c4 bellhousing for a 2.0 as well as a specific covertor and a flexplate. After that you need the correct rubber mount to mount to the transmission crossmember. Also don't forget the starter,and the downshift linkage that works off of the carb and the downshift  link that connects to the trans.
I wish i could tell you where to get this stuff as junkyards have just about run out of pintos in allot of areas . Ebay sometimes has stuff. never know who might have stuff here as well.
I have the little link that connects to the trans, I THINK i have the downshift "bar" that goes from the carb to the trans,and i have the Pinto c4 valve body that has a B&M kit in it .It shifts pretty hard. I'm using a V8 valve body in my conversion now so i wont need the old pinto 4banger body.
After all is said and done might be easier to rebuild the 4speed ?? Just a thought.
Hope this helps!
Robert
jbpinto
Hey folks new on the site here .I have a question for the Pinto folks out there. I just bought a pinto  that was built back in the late 70`s .It is a 71 runabout  .Car has been sitting up since early 80`s  I need to know how to get a C4 over in this thing. Here is the combo it has . 2.0  with cam .offy 4brl. intake ,mallery duel point. here is the kicker  guy parked it because he trashed 4 speed .I have a brand new  C4 out from behind  a 79 ford 200  6  cylinder. I have already took trans off of 6 cylinder  ,but I do not know what I need to do about  bellhousing  ,converter  & flywheel .  Remember my pinto is a  71 model with a  2.0    I need to know what I need to do  to get this C4  hooked up  to it .  Any help would be greatly appericated
