Date: 08/09/2018 07:49 am
Date: 08/30/2021 03:20 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 10/24/2018 07:35 am
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Date: 04/13/2017 04:56 am
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
  • Online today: 584
  • Guests: 395
  • Total: 395
302 / AOD> will it fit?
Started by hoots, September 23, 2005, 01:20:28 PM
WOW!
Now that has to be the cleanest V8 install I have seen.
GREAT JOB!!!!!!!!!
hoots
Yeah, 302 with C4 tranny with the truck housing, no BFH required. It's quite the process of getting all parts in place. The tranny has to be installed from the bottom while the engine is lowered in place, without the exhaust manifolds on yet. Once the engine and tranny are bolted together then I lowered the unit to install the manifolds, then raised up to install the engine mounts. Here's some pics. Check in the 'Your Project' section here, I have a thread called 'work in progress'.
Hey Hoots!!!!Take some pick of your engine compartment. I wanna see how you did it. You have a 302 right?
it will fit with some clearancing from a BFH on the transtunnel. It is longer than a C4 and the mount will be further back a bit so a custom bracket would have to be fabbed up.
hoots
My C4 doesn't have long enough legs on the interstate. Has anyone installed the AOD (with the 302) in a Pinto?
