78 wagon instrument y
Date: 04/30/2018 07:41 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 09/17/2024 12:35 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
Date: 09/12/2018 12:33 pm
Date: 11/08/2019 10:01 am
  • Online today: 553
  • Guests: 427
  • Total: 427
timing belt alignment 73 2.0l
Started by pintowgn73, September 21, 2005, 08:54:54 PM
Hey Pintowagon73,
While changing your timming belt.
Make sure you take a good look "WITH A FLASHLIGHT" at the crank timing gear.
I have seen these gears worn 1/4 of the way through the cog.
pintowgn73
yeah, I checked all the vacuum lines, pcv, etc. I looked at the timing marks last night and the marks are off. with the cam at the mark, the crank is at about 12deg btc. I'm going to get a new belt and throw it on and see how the car runs.
Hello pintowgn73,
Yor engine looks great! I love the look of the 2.0. SIMPLE :)
Anyhow... Have you checked your decell valve?
Is the clamp on the PCV hose tight?
If your timming mark is that far off I would say that your timming belt has stretched beyond its useability.
Or your crank gear has wear way beyond use. OR both.
Just things to take a look at.
pintowgn73
car is completely stock. stock carb, exaust everything. sticker is still on the valve cover, has new points, cap, rotor and wires. I have replaced the intake manifold gasket and carb base gasket due to a vacuum leak, but have been unable to find any info for checking the timing belt to see if it was set right. I've had the car for about 2 years or so and have only put maybe 3-400 miles on it. here's a pic of my engine compartment
Hello pintowgn73.
The Pointer should be at the bottom 6-Oclock and pointing straight UP.
The dot that mcrouthamel refers to is actually a spot face or drilled hole in the head NOT the block.
What carb are you running?
Are you checking the timming with the vacuum advance disconnected?
What modifications have you made to your engine?
Header? big cam? manifold?
Be sure to check the PCV valve and the hose running to the PCV valve.
Make sure the 'CLAMP that goes to the nipple on the manifold is tight.
Do you still have the Decel Valve in place?
Is the diaphram leaking?
mcrouthamel
There should be a dot on the block under the cam timimg pully.
Line the pointer on the cam pulley backing plate up w/ the dot./
Mark
pintowgn73
ok, so I have gone through this forum and searched for this. no one has given a clear way to check the timing belt on a 2.0l. my 73 has a rough idle and a very bad flat spot in the power bandfrom about 1/4 to 3/4 throttle. I have tried to check the timeing and it is WAY off on the crank shaft with the light. I can see the pointy mark on the camshaft but I don't have any idea where to line it up with. any help would be greatly appreciated. thanks.
jim.
