Intake manifolds
Date: 03/06/2021 03:04 pm
Date: 02/18/2017 04:44 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Date: 08/05/2018 01:58 pm
Date: 01/19/2020 09:06 am
Date: 08/06/2021 02:23 pm
  • Online today: 1,185
  • Guests: 626
  • Total: 626
stumble/lag
Started by sundug, January 09, 2024, 10:30:02 AM
 Is the choke open (warm engine) or partially closed (cold engine)? Maybe a low float setting? If the level is low it may take a delayed time for the fuel to pull through the venturi. It might be low due to a weak fuel pump or a clog that is BARELY getting enough fuel to idle and squirt the accelerator pump - only. If everything is stock that car might have a De-Cel valve and it might be getting triggered to bleed air when the throttle is opened. I'm not familiar with those (always gets removed) but others have reported problems with them.
Are you sure the engine is running on all cylinders? When I got my 73, 2.0 one cylinder wasn't firing. It drove but very slowly. I found the valve seats had worn to the point there there was zero lash on some of the valves and compression was very low. Setting the lash to specs got all cylinders above 100 though not equal. Hope one of those helps.
sundug
1973 2.0 with stock carb, accelerator pump set to lower pin, looks like a good squirt of gas when I work the linkage, but I still have a major stumble when accelerating. Timing 8* BTDC. Any ideas? Thanks!
