Date: 10/05/2017 02:26 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
convert to stick
Date: 05/19/2018 09:26 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
Date: 01/21/2023 04:19 pm
Date: 07/01/2019 03:17 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
  • Online today: 2,670
  • Guests: 581
  • Total: 581
question about pinto V8 swap
Started by IWANTAPINTO, September 21, 2005, 03:50:14 PM
77TurboPinto is correct. And he did not even mention getting the pipes set up or the radiator thing worked out or the transmission cooling lines or the powersteering lines. I used a c4 out of a grand marquee. And I mean to tell you it was not "easy". But I did it!!!!!
The term "easy" is very subjective. I did a t/c swap into my pinto, and I think it was easy.
Tranny: The worst case would be you would have to do one or more of the following even if the tranny bolts to your engine: modify the tranny mount, have the driveshaft length changed, re-locate the hole in the floor for the shifter, splice the wires to the tranny, convert the clutch linkage or type(rod/cable/hyd.), open the tunnel with a big hammer to fit the bell (MII v8's have a very small bell housing. MIIs and pinto's are not identical).
Rear: No, 80's stangs have coil springs. You would need to do lots of work to it. You can get an 8" from a mid 70's pinto/bobcat/mustangII, they bolt in. I have been told that a granada rear will fit with minor work. I installed one from a 60's stang with not too much effort.
PS: Help section?
IWANTAPINTO
ok let me rephrase that a little. Will the manual transmission and rear end from an 80s mustang fit into my 1978 pinto hatchback easily?
Any thing will fit given enough time and money.
IWANTAPINTO
I was wondering if the manual transmission, drive shaft and rear axle from  an 80's mustang would fit in/on my 1978 pinto hatchback. If any of them will, please reply, and fill me in on the modifications i will need to make if there are any.
