Date: 02/08/2018 02:26 pm
Date: 10/28/2018 08:45 am
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
postal pinto
Date: 06/03/2020 09:31 am
Date: 02/10/2017 09:30 am
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Date: 02/18/2017 05:52 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
  • Total Topics: 16,272
  • Online today: 186
  • Guests: 114
  • Total: 114
Crank pulley and outer timing cover Help
Started by Creedmoor, April 19, 2023, 01:13:42 PM
rob289c
I'm not sure if the propane torch would be hot enough.  The pulley has been on the snout for over 40 years so it might take a bit to free it up.  If that's all I had, I would give it a try.
rob289c
Creedmoor
Quote from: rob289c on April 22, 2023, 07:13:49 PM
If the junkyard allows it, bring a Mapp Gas torch.  You may need heat to get the pulley off.  Mine took a lot of persuasion to get off.  In the end, the heat did the trick.  I don't think you need to take the pulley off but it may make it easier to get the timing cover off in the long run.
Think a regular propane torch would work?  Don't have a Mapp one and I'm not gonna even try to haul the oxy / acetylene rig down there.
rob289c
rob289c
davidpinto
I 'VE NEVER HAD TO REMOVE PULLEY TO GET THE COVER OFF.YOU HAVE TO FENAGLE IT A LITTLE TO FIND THE SWEET SPOT AROUND BRACKETS .PULLEY IS NOT PRESSED ON .
D BARHAM
Creedmoor
Finally found a junk yard with a couple Pintos. One of which was a 2.3 with the outer timing cover still there. That's what I needed. Pulled the bolts and....discovered that you need to pull the crank pulley to remove said cover.  70 mile round trip. :-\  So, two questions:
Is it true you need to pull crank pulley to get the outer cover off?
How hard are these pulleys to remove?  Been sitting there for a loooong time. Spray lube, impact, pry bars, three jaw puller?  Any tips or advice appreciated!
Thanks.
