Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
hood for a 79-80
Date: 11/30/2018 10:55 pm
Date: 02/05/2020 11:06 am
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
1980 hood needed
Rear Bumper
Date: 07/26/2021 01:08 pm
80 pinto original
Date: 08/04/2019 10:45 am
  • Online today: 1,166
  • Guests: 70
  • Total: 70
Valve adjustment on 1980 2.3
Started by Creedmoor, March 07, 2023, 12:33:57 PM
Creedmoor
Thanks. That'll save messing with a valve cover that DOESN'T leak!
The 2.3 engine has hydraulic lifters. Because of the way they work (the static pivot point is hydraulic) they should probably be called plungers since the cam is pushing down on them rather than lifting  (hence the term lifter) like a in block cam engine does. The earlier Pinto's (71-74) if they had the 2.0 EAO overhead cam engine (and I believe also the 1.6 Kent British) engine OHV) needed the mechanical adjustment. I'm not sure about the V6 Cologne engine. Both the 2.0 EAO and the V6 Cologne engines were German. The 2.3 was the only American Pinto engine.
Creedmoor
Does a 1980 2.3 require periodic valve lash adjustments.  Or are there hydraulic lifters in there?
Thanks for any input!
