Date: 08/26/2018 06:35 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 03/05/2017 03:27 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Date: 11/05/2020 06:32 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
  • Online today: 600
  • Guests: 362
  • Total: 362
Rebuilding 1973 type e 4 speed manual
Started by LongTimeFordMan, February 14, 2023, 08:55:06 PM
LongTimeFordMan
Quote from: LongTimeFordMan on February 14, 2023, 08:55:06 PM
I have   a spare speed that seems to be in pretty good shape except that the input shaft seems to have a bit of wobble.... maybe 1/8" at the tip so i was thinking about replacing
The bearing.. any ideas..
That's really common with the bearings typically used on input shafts and is not an indicator that there's anything wrong with it. Ball axle bearings do it too, even when new. It's from clearances built into the bearing itself.
72DutchWagon
Ford 4 speed type E or "rocket" gearboxes seem to be still catered for quite well in the UK, see attached image for just one parts provider, I do't think you should have to many problems to get things send over for your rebuild.
warhead2
May do a search on this forum. you might find something. I know parts for the fog are few and far between. Unlike the T5 there are lots of parts
Sent from my SM-G965U using Tapatalk
LongTimeFordMan
Has anyone had experience rebuilding an ea4ly 2.0 FOG 4 speed?
My 4 speed is beginning to sound a bit raspy when i decelerate  in 2nd gear
