Date: 08/08/2017 01:44 pm
v8 springs
Date: 05/07/2017 04:46 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Date: 01/10/2022 03:41 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
  • Online today: 587
  • Guests: 169
  • Total: 169
Crank Pulley Removal 2.3
Started by rob289c, October 02, 2022, 06:27:40 PM
rob289c
SUCCESS!!!  A little heat from the MAP torch and it pulled off!  And I didn't have to get out the heave artillery (oxy-acetylene torch).  Next is to remove everything from the intake side of the engine.  I pray for no broken bolts...
rob289c
rob289c
I keep spraying penetrating oil and tapping but still not budging.  The crank pully bolt came out but the washer is still in there.  I haven't been able to get it out yet.  Do you think that is holding anything up?  I think it should still pop off.  I put my smaller three arm puller on and was able to grab the outer pulley and put some tension on it.  Maybe overnight while I'm sleeping the penetrating oil will work and it will pop off?  Wishful thinking...
What is the function of the two holes and notches in the snout of the pulley?  Is it for using some type of factory puller?
rob289c
rob289c
I searched the archives before posting, but I need advice for removing the crank pulley.  I put my 2-arm puller behind the inner groove and started to bend it so I stopped.  Would it be better to put the puller in between the two belt grooves?  Or is there a better way?  There doesn't seem to be a good way to spray penetrating oil so it gets onto the crank snout.  I've never had a hard time getting one off but this one has likely been on for a long time.  Any advice will be appreciated.
rob289c
