1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 08/13/2018 02:46 pm
Date: 02/18/2017 05:52 pm
Date: 04/06/2017 12:13 am
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
  • Online today: 802
  • Guests: 294
  • Total: 294
Engine serial # confirmation and carb question
Started by mdspeedster, January 30, 2022, 10:08:01 AM
mdspeedster
Davidpinto and Wittsend,
Thanks for your responses.
A VIN is not available since the engine is installed in a track roadster.
All four of my intake ports are round but some 2.0 and 2.3 intake gaskets have larger, oval-shaped holes in #1 and 4 ports and won't work.
The rest of the gasket matches up (bolt and port holes) including the water port in the center of the four intake ports.
Why the difference?  Does that help to identify the engine?
davidpinto
DEFINETLY A RANGER MOTOR , COULD BE A 2.0 OR 2.3, RANGERS CAME WITH BOTH FROM EARLY 80s AND HAD 1BBL CARBS.
  COULD'NT IDENTIFY BLOCK WITH OUT VIN#
D BARHAM
If it helps the Escort did not use the Lima 4 cylinder in the Pinto. So, you can rule that out.
davidpinto
IT COULD BE A 2.0 MOTOR OUT OF A RANGER,THEY HAD 1 BBL CARBS.I CAN LOOK UP YOUR #S TOMORROW.
D BARHAM
mdspeedster
My engine serial number is D8EE-06015-BA.
Am I correct is deciphering this as a 1978 2.3L Pinto (not Escort or truck?)?.
Am trying to find a replacement carb or carb rebuilding kit.
It's a 1-barrel with 7632S stamped on the base, two other numbers on the carb are 8603 and 8509.
Can't find these numbers cross-referenced anywhere.
Had a small engine fire this past summer so rebuilding wiring, etc.
Appreciate any help understanding this info, crossreferencing.
Bruce
