76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 08/09/2018 11:09 am
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Date: 08/22/2017 09:21 pm
Date: 09/21/2018 11:35 am
Radiator
Date: 05/27/2018 06:07 am
Date: 11/08/2020 02:10 pm
Date: 02/27/2017 10:10 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
  • Online today: 437
  • Guests: 447
  • Total: 447
Help Installing Rear Spoiler
Started by Late Models Best, September 19, 2005, 08:28:36 PM
My 78 has the big glass as well, and I can see what tony is talking about. I have never seen that item for the big glass. Yes, you need to remove those 2 "filler" panels. Very easy, you can reach the nuts by going up thru the side marker light access panels (just be sure you get all of them, 6 i think, the panels are not sealed or glued. if it will not come off, you missed some fasteners).
Hello Tom D.
Yes there should be a vertical lip that the all glass hatch RALLYE wing attaches bolt to using large head philips head screws.
There should also be hardware located on the wing itself for attachment.
Every "USED wing I have seen is missing this hardware.
I have used 3M attaching strip to use instead of the factory hardware.
The RALLYE wing consists of 5 pieces.
Most USED wings only come with 3.
There are 2 filler pieces that are required to install the RALLYE spoiler.
Late Models Best
I was lucky to find a Rallye factory rear spoiler for my 79 Bobcat all glass hatch back.  Does anyone have a Pinto or Bobcat with one of these type spoilers.  Or has anyone ever installed or removed one.  It seems that I will have to remove the filler piece that is just below the glass and in the corners.   Is there some kind of angle iron to attach it to?    Any help or advice is appreciated
Tom D.
TJD
