Early 2.0 engines
Date: 05/09/2018 12:45 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
pinto for sale
Date: 09/11/2016 09:47 pm
Date: 10/24/2019 01:43 pm
Date: 05/18/2020 10:22 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 11/04/2018 02:34 am
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
  • Online today: 481
  • Guests: 320
  • Total: 320
Fuel tank for 74’ wagon
Started by Dak_triad, December 30, 2020, 06:09:44 PM
PintoRoyL
That would be pretty cool if you can do it, I have always liked matching trailer/tow vehicles. I currently own two El Caminos (technically, one of these is a twin cousin, a GMC Caballero) and a 3rd body on frame Elky without a front clip that I am hoping to turn into a trailer after I strip all useful parts.
SpaceCowboy1979
While on this subject does anyone know what year wagon
Gas tanks are adaptable
Hopefully all same
I have 3
2 are 1979
1 is 1980
I had all 3 restored
My
Dream is to take 2 wagons cut the back off both
Then join them together.
Making a 4 wheeled trailer
And pulling with my 1979 crusing wagon   with port hole windows
With the hockey stripe graphics package
Matching trailer
Need all three for fuel for camping generator and or water
But dreams dont always come true
If adaptabal I will keep you in mind
PintoRoyL
Do they sell tanks at the yards in your area? I am near Seattle, Wa. and the yards here puncture fuel tanks before setting the vehicle out.
Dak_triad
Quote from: flash041 on December 30, 2020, 08:55:18 PM
No one makes a wagon gas tank at this time. You need to find a good used one, or have yours repaired. Getting yours repaired is probably the best option.
Yea sorry I was wondering more about fitment. Mine doesn't leak (as of now), it has a giant dent in the bottom though so my gauge reads empty at half a tank. There's a radiator shop in town that said they could fix it but I'd rather get a new/undented if I could. There's actually a 73' wagon in a scrap yard near me, I was going to pull out the tank and give it a try.
You state the need for a tank but not why. More often than not a fuel tank is a problem because of a leak. The wagon tank has the sender mounted in the side of the tank. The sender itself or its seal could be leaking. A leak could also be from the fuel outlet line (rubber), the vapor recovery line (rubber) or the filler neck gasket (rubber). Unless you know for a fact that tank is leaking from rust through it maybe leaking from other areas.
If the tank is know to have holes there are repair places as well as sealants (such as Bill Hirsch) https://www.hirschauto.com/Gas-Tank-Sealer-_-Repair/products/4/ that can be poured in a removed tank to seal them internally. I'm not recommending Hirsch specifically as I have heard mixed reviews on these 'pour in' type sealants. I'm just letting you know they are available. Make sure they are ethanol compatible.
flash041
Dak_triad
Looking for a fuel tank for 74' wagon.
Everything I've found say 71'-73' or 75'-80'
I seen something saying the 74' mustang II is the same
If that's the case I'll do that. Anyone know?
-joe
