Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 02/21/2022 11:11 pm
80 pinto original
Date: 08/04/2019 10:45 am
1978 hatch back
Date: 11/29/2019 03:18 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
Date: 06/18/2018 03:47 pm
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
  • Online today: 506
  • Guests: 214
  • Total: 214
Desert Valley received another Pinto
Started by Dtmix, December 02, 2020, 11:05:24 AM
Dtmix
Wow! I learned something new! I had no idea that there were three different pedal assemblies! I presumed that all parts were kept the same from 1971 through 1976 except for trim pieces until 1977/78 front facias and 1979/80 front fenders. Thanks for the lesson of the day!
Happy Motoring!
Dan
I was told there are FOUR different pedal arrangements used in Pinto and I believe that is not including the Automatics! I'm sure the change from 71-73 to the Mustang II based cars is one of the changes. I think that booster/Non-booster was another and the fourth??? I never knew this until I attempted to put 79 ESS pedals in my 73 and they didn't fit. Thankfully the late Fred Morgan was willing to do a swap with me and we met up at Knott's. So, just make sure you have you are getting the proper year/type pedals. Also make sure you get the connection pins/clips, plastic bushings etc.. Most of the plastic bushings are worn but something is better then nothing.
HOSS429
i need   a set of clutch pedals as i want to change my car from an automatic to a 5 speed some day .. i may check with them .. i also need a rear end but i think i will just make one from a 8 inch out of something else .. a friend has several mustang 2 8 inch rears but he wont sell me one .
Dtmix
I get newsletters from Desert Valley Dismantling yard as they are an excellent source of desert dry body parts. They just received a 1974 Pinto, so take a look to see if there's pany parts that you need?
https://www.dvap.com/salvage/1974-ford-pinto-run-about-2-door-hatchback-74f04580b/
Happy Motoring,
Dan
Happy Motoring!
Dan
