Pangra wanted
Date: 02/05/2017 01:58 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
Date: 06/05/2018 09:13 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 02/14/2018 01:34 am
Date: 01/18/2017 05:35 pm
Bumpers
Date: 07/06/2018 04:47 pm
1972 pinto grill
Date: 02/27/2018 12:13 am
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
  • Online today: 802
  • Guests: 172
  • Total: 172
Starting help
Started by Canadiandavid, September 14, 2020, 06:41:58 PM
Yes, looks like you have them.  They are about 3" long and are held in with a screw under the seam sealer.  Lots of people take the side panels but forget to grab the extensions.
Canadiandavid
I may be dirty and smelly but  in the dark I'm just smelly
Quote from: Canadiandavid on September 19, 2020, 08:18:25 PM
There’s a drip rail that runs from the door all the way to the back hatch, is that the one you’re referring to?
There is a little extension that wraps around the rear corner.
Canadiandavid
There's a drip rail that runs from the door all the way to the back hatch, is that the one you're referring to?
Quote from: Canadiandavid on September 15, 2020, 06:37:26 PM
I could send you some pictures if you could ID it, or a vin. I know it’s got some panels inside and if you pull them off it looks like there’s frames for the windows
All wagons were made from the same platform.  Cruising wagons and the delivery wagons all have the window frames behind the side panels.  There are lots of unique items that come on the cruising wagons but I am not sure all of the ones on the delivery wagons.  And 77-78 are different than 79-80.  I have read that the delivery vehicles do not come with a back seat.  Also, the drip rail extensions are on all wagons that have the side panels installed from the factory.  Most of the time, those items are not removed from the donor vehicle so that is one easy tell sign if the side panels are factory or not.
Canadiandavid
Unfortunately I barely have room for my wagon. My land lady would murder me if I brought two more pintos home
You couldn't pay me enough money to live in ANY City........I'm an hour N of Edmonton.
Very unique property - no neighbors , long lane way & no one can build near me. Ever.
Canadiandavid
Quote from: Reeves1 on September 16, 2020, 06:37:31 AM
Where in Canada ?
I'm in AB.....
Calgary dude! You couldn't pay me enough to live in Edmonton lol
Where in Canada ?
I'm in AB.....
Canadiandavid
Quote from: rob289c on September 15, 2020, 06:36:19 PM
Nice looking wagon.  Glad you got it running.  Keep the questions and posts coming.  It can get boring when no one is active!
Oh don't worry I will, I'm mechanically retarded and have bad luck on my side. I love these cult cars though, it's like a family I never knew I had
Canadiandavid
Quote from: TIGGER on September 15, 2020, 01:01:58 PM
Is that a true sedan delivery?
I could send you some pictures if you could ID it, or a vin. I know it's got some panels inside and if you pull them off it looks like there's frames for the windows
rob289c
rob289c
Canadiandavid
Quote from: dga57 on September 15, 2020, 07:38:37 AM
Welcome aboard, David!  That's a nice looking wagon!
Thank you, I fell in love with is as soon as I seen it on kijiji (Canadian classifies website)
Canadiandavid
Yeah, Canada may be sweet but we get some pretty gnarly rust with all the salt and calcium they spread on the roads in the winter. Thanks for the tip!
LongTimeFordMan
Good preventive maintenance might be to get a batt terminal cleaning tool and battery terminal anti corrosion spray ( autozone)
Clean the terminals and inside of the cable connectors ti clean shing metal shows.
Then spray battery terminals and inside of the cable terminals.
Install the cables on the battery and liberally spray the terminals and around the terminals on the battery.
Also the anti corosion spray is useful to prvent corrosion and rust on other stuff in the engine compartment.
Canadiandavid
Well I got er figured out, it was a crummy ground on my battery, I knew it had to be something simple but man I still feel dumb
Canadiandavid
Hey there, bran new to the group/ forum and I'm sure it's been asked before at some point but I need some help. I recently bought a 1980 wagon with a v6 and a five speed and when I bought it the starter was a little iffy, sometimes it would fire up sometimes the starter would spin but the little gear wouldn't kick out and spin my flywheel so I changed my starter but now it won't start, I got the power to the starter, I got a good battery, I changed the icm, the voltage regulator and the starter Solinoid but now when I turn my key the solonoid just goes *clunk* and has no effort past the Solinoid. any help will be greatly appreciated. Keep in mind I'm not a mechanic by any stretch of the imagination just a guy with tools and a garage. Thanks for your input
~David
