Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
parts needed
Date: 02/20/2017 07:58 am
Windshield
Date: 01/15/2022 09:31 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
  • Total Topics: 16,268
  • Online today: 175
  • Guests: 109
  • Total: 109
Pinto Powered Mustang Roadster
Started by rob289c, July 19, 2020, 06:19:07 PM
Progress for sure. Keep at it, it will eventual be complete. Sometime the last "mile" is the hardest.
rob289c
Every little bit gets me closer to completion...
rob289c
rob289c
Yesterday (Saturday) I sanded the urethane I sprayed last weekend.  It seems to have come out pretty nice.  Next Saturday I will wipe any residual dust off it with a damp sponge, then on Sunday, solvent wipe, then paint.  Today I sprayed various parts with interior black.  The paint is almost 50-50 leftover semi gloss and satin.  It looks pretty glossy after spraying; I hope it flattens out a bit after curing.
rob289c
rob289c
Sprayed urethane today.  Next will be to sand it smooth, then color.  I got good coverage, but have tiger stripes.  I will have to widen the fan and open the fluid when I spray color.  The pics look similar to the previous posts, but it is a different product on the car now.  I may sand it next weekend but don't think I will spray color yet.  I need to take my time.  I have my HS reunion next weekend and have to look at a siding repair at my Mom's house.  I need to clean out the garage (sweep, leaf blower, power wash) to get and dust/debris out so I can spray in a clean environment.  I think waiting another week for color will be better in the long run.  Anyway, I made progress over the last two weeks.
rob289c
rob289c
This afternoon I sanded the truck lid, quarter panel extensions, and side scoop inserts to prepare for urethane.  I then masked the car.  Tomorrow I plan to wipe the body and other parts with solvent, then tack and spray urethane primer surfacer.  I hope to get 4 good coats, or as many as I can spray before I run out of material.  I will let it cure through the week, then sand it smooth next weekend.  At that point I will be able to spray color when my schedule allows.  Getting closer...
rob289c
rob289c
We spent T-Fri in San Antonio to watch our son graduate from Air Force Basic Training.  Like when our daughter did it a few years prior, it is a proud experience for parents.
Project update:  before we left I had sprayed pieces/parts with epoxy.  This AM I sprayed the floor brackets, dash brackets, bumper/headlight brackets and the inside of the interior panels with black tractor enamel.
rob289c
rob289c
This afternoon I sprayed epoxy on various brackets, the dash, glove box door, ash tray, interior panels and a few spots on the body.  I beat the storm that is just arriving.  Everything will have to sit as-is until I get back from TX.  I'm not sure on my next step.  I wasn't going to worry about primer surfacer on the dash but I think it will be better in the long run if I do.  The reconstructive bodywork is visible and the urethane might hide it a little better.  If that's next, I need to prep the body and spray it and the dash at the same time.  Once a product is mixed and in the gun, I don't want to have to mix up another batch down the road.  I want to do it all at once.
rob289c
rob289c
Progress today:  I was out in the garage at 0600 grinding the welds I did yesterday.  Then I put away yesterday's tools, and started picking up shop.  I had to quit at 0700 to get ready to go to the barbershop.  After that and a few errands, then I pushed the car outside, blew off the dust and other debris with compressed air.  I then wiped the body and interior with a damp sponge.  I seam sealed the drip rails and the seam between the bottom of the quarter and the rocker, as well as some other areas that needed it.  I continued to rearrange, sweep, and get the garage ready to spray epoxy.  Tomorrow I start a week off from work.  I plan to shoot epoxy after running morning errands.  I won't make any other progress until next weekend as I will be going to San Antonio to watch my son graduate from Air Force Basic Training.  Next weekend I plan to spray the interior parts black.
rob289c
rob289c
Yesterday I did something that I have thought about a lot but didn't want to do.  I tied the rear of the Pinto transmission hump to the rear floor section/driveshaft tunnel of the Mustang body.  The hump and tunnel are of different shapes and sizes so I knew it was going to be a PITA to fabricate with no special metal working tools and then getting it tacked and welded in place.  The right side was pretty easy as it was just a filler piece that with a little massaging, it went together pretty easily.  The left side was a little more complicated.  I had to fab a sort of a block off panel, then the filler piece.  Neither side is pretty, but with a little grinding, primer, seam sealer, and paint, it will be a functional repair.  It is solid and now the firewall/trans hump are tied to the rear of the body.  Like most parts of the project, it took way more time than I thought it would at the onset.  My plan is that once all together I want to cover the hump and down over the frame rails with diamond plate.  That will give it a more "finished" look.  It is still going to be a "step into" cockpit and will not have full floors.  I'll be sure to post pics when complete.
The other thing I have in work is I have a small metal shop fabricating the 9 windshield clips I will need to hold the windscreen in place at the cowl/firewall.  They are making them out of stainless so I won't have to coat them.  Not sure of ETA, but I don't need them right away anyway.
I will make more progress today and will try to get a progress report posted this evening.
rob289c
rob289c
I love your 'Vair!  A friend in HS had a '66 2-door that we used to tool around in.  Another buddy had a '65.  I like the ones that were like a pick up but you (I) never see any of those.
As for the door jam area, I am planning to just paint it body color.  I am also looking to fabricate a triangulated piece out of round tubing that will be welded to a hinge at the firewall and extend back to where the striker plate would be to function as a door.  Really it will give the illusion of safety so neither driver nor passenger accidentally falls out.  It will just be pinned closed.  As for wood to give it a finished look, I have no talent with wood and limited wood working tools.  I am planning to cover the sides of the firewall with diamond plate to give it a "finished" look and also diamond plate on the floor sections to cover up the raggedy transmission hump and give that a more finished look.
Last night during my "I can't get back to sleep" session, I remembered that I still need to get the clips that will hold my windscreen to the cowl fabricated.  I need them ASAP as they will also need to be epoxy coated and painted.  I would like to not have to do another epoxy session...I want to spray everything at once while I have it mixed and in the spray gun.  Especially the small amount I will need to mix and spray on the clips.  Improper planning on my part...I should have had them fabbed already.  I may opt to have them powder-coated at the sheet metal shop as they perform that service too.  Then I won't have to worry about epoxy and paint.  Anyway, we're getting closer to the weekend so I hope to have more progress to report by Sunday.
Edit: on the inside vertical edge, I am going to install black windlace over the edge to cover it up.  It is the same material that the Mustang had from the factory.
rob289c
You seem to be very happy having the weather to get back at it. it is really coning along. I was curious what the plans for the area circled in red are? It would seem wood might be a good product to make a "finisher" on that end.
BTW (as inspiration) I finally got my Corvair wagon running decent enough to get it to Cars & Coffee last weekend.
rob289c
This morning I sanded the body.  I had sprayed the epoxy 2 or so years ago so it needed to be abraded.  I used 600 grit.  Next weekend I plan to spray more epoxy on various parts, brackets, etc and weld the Pinto transmission hump to the Mustang driveshaft tunnel to tie it all together.  That work area will need a squirt of epoxy too.  I also found a high spot on the left sail panel and sanded it down so that will need a squirt too.
I am going to paint the dash pad with Krylon Fusion Hammered Texture Black.  It claims to adhere to plastic and vinyl so it should be suitable to spray on the body-filler repaired dash pad and the hammered texture should hide the repaired areas better.  I will clean with solvent first, then adhesion promotor, then the paint.  Fingers crossed it comes out looking nice.
I leave for San Antonio on the 16th and am taking the 15th off.  I am hoping by then I will have sprayed 4 coats of urethane primer surfacer.  When I get back I can sand it smooth in preparation for color coat.  Hopefully in 2-3 weeks the body and paint portion of this project will be over!
rob289c
rob289c
I made 0 progress on my project this past weekend.  I am cleaning out and organizing two rooms that my wife and son have badly cluttered over the last several years.  I am reclaiming one for a grandchild nursery and the other to be a guest room.  I found things I haven't seen in years.  Tossed some, will donate some, some have been stored in a better way, and some will be returned to use now that I know they are still in existence.  I hope next weekend is more productive on my project!
rob289c
rob289c
Yesterday (Sunday) I wire wheeled the inner quarters from the Mustang.  Paint removed and wiped down with paint prep solvent.  They are ready for epoxy.  That was pretty much it for my project work.
I think next will be to scuff the body that is in epoxy in case I sand through to metal or body filler so I can touch it up while I have epoxy in the gun spraying other parts.
Most of the day was spent weeding the garden, weeding around the patio, trimming shrubs, raking the clippings, weed whacking, mowing.  Worked like a dog!
rob289c
rob289c
Today I reviewed my inventory of paint products and made a list of what I need.  I want it all in stock so when the time is right I can prep, mix and spray.  I went to NAPA and placed my order.  They had everything except for the quart of FP 410 Primer/Surfacer.  That will be in Monday.  Afterward I went home and sanded the dash, glove box door, and ash tray.  They are all but ready for epoxy and black paint.  I may spray them with a few coats of primer/surfacer before the paint.  Tomorrow I will do the final prep on the rear inner quarters.  They will then be ready for epoxy.  I made lists of which parts and assemblies need which coatings so I can be organized and not have to re-mix any products.  I'm sure something will be forgotten but if I can keep that to a minimum, that will be a win.
rob289c
rob289c
Hopefully a lot more this coming weekend!
rob289c
I'd say you made pretty good progress, all things considered.  We're going to be experiencing that heat wave too.  Stay hydrated and try to stay in cool places!
Dwayne :)
rob289c
Yesterday (Saturday) I cleaned, sanded, and did body work on the Mustang II header panel (nose piece).  I used body filler on the top and sides where it will be visible and only sanded the underside and other unseen parts.  It will get few coats of primer surfacer, then bodycolor.  After that I got the dash pad back out for a little more massaging.  So more body filler and sanding.  I think I have it as good as I am going to get it.  I also continued stripping the green paint off the rear inner quarters.  The need to be scuffed, then epoxy, then interior black.  For only a few hours  of work I did OK.
Today we went to a car show in the fastback.  I had a great spot next to the lake (Owasco Lake, one of the Finger Lakes in NY).  80 degrees, low humidity and sunshine all day.  I heard they had a record # of cars, but don't knw the actual count.  I know they have topped 700 cars several times in the past so there were at least that many.
We are in for a heat wave this week.  I hope next weekend will be more productive on my project.  That's all Folks... ;D
rob289c
Quote from: rob289c on June 14, 2024, 08:32:31 PM
I will report tomorrow evening on what I am able to get done.
I'll be waiting for your report!  Have a great weekend!
Dwayne :)
rob289c
Tomorrow is Saturday and I need to make the best use of the morning and early afternoon.  I have to go to a neighbor's kid's birthday party (begrudgingly) and then I will be participating in a Father's Day Car Show on Sunday in my home town which means no Sunday progress.  I mowed the lawn yesterday so I don't have to do it tomorrow and maybe I can get some more time on my project.  I will report tomorrow evening on what I am able to get done.
rob289c
I know projects can seem unending, but I think you're moving along magnificently!  Glad you found some time to work on it!
Dwayne :)
rob289c
I finally got some garage time over the weekend.  Some progress:  I brainstormed what to do about a windscreen.  I am thinking it is going to be plexiglass or some other clear polymer.  I made a template out of poster board.  I had to think of a way to mount it.  I came up with an idea for clips and built one out of cardboard from a toothpaste box.  It will allow me to mount the lower edge, and will provide a 45 degree (or so) windshield rake.  My other Mustang is a 40 degree rake but for this application I think a 45 degree will be good.  I would like the metal for the clips cut and bent professionally with a shear and brake so they look right and not a cob job.  I will have to fab some sort of braces for the top of the windscreen and attach to the dash or some other secure spots.  I also removed the Mustang II header panel and removed the grill from the header panel.  I will be doing body work on the header panel to prep for primer and paint.  I will also clean up the grill so it will be ready to reinstall after the header panel is in paint.  I also popped the orange steering wheel off so I can prep the visible portion of the column for black paint.  I had to use my harmonic balancer puller to get it off.  It goes right on and off now.  I will not be re-using the orange steering wheel.  I have a 13" three-spoke wheel with a Mustang center.  Over a year ago I ordered and received a rear deck package tray that has provisions for 6x9 speakers.  64-67 Mustangs didn't have factory 6x9 rear rear speaker cutouts so this aftermarket part provides that option.  I will have to trace and cut out the openings when I get to that point.  I finally opened the box and set it in place to see what it looked like.  I will make it work.  I got the rear inner quarters out of hiding and did some corrosion control and paint stripping.  The next "major" step will to get all the interior parts painted black.  Dash, Dash Pad, Rear Inner Quarters, Junk Tray, Steering Column.  Then I can start prepping the body for primer/surfacer and top coat.   I took inventory of the paint products I have left over from another project, visited my local NAPA, and made a list of what I need to buy to ensure I have enough product to complete the job.  There is so much left to do.   I need to secure the brake lines to the frame.  I need to fabricate and install fuel supply and return lines.  After paint I need to get the wiring harnesses in place.  I need to get a battery box and mount it in the trunk and run pos and neg cables to the front.  I still think I can get this thing to a point that I can run it around my circle before I have to put it away for the season.  I need to make the best use of my time but I still have other automotive maintenance and home/yard projects to do.  This coming Sunday is Father's Day so I go to a car show in my home town in my Fastback.  That kills a day of productivity.  Some time in July I will have to go to TX to see my son graduate from Air Force Basic Training.  That will keep me from making progress.  If I keep making small steps of progress I can get this thing done.
rob289c
rob289c
I have thought about spraying some type of smooth but textured product on before the black paint.  I'll have to do a little research to see what's suitable and available.  Or maybe not...
I won't be making any progress this weekend.  I'll be out of town.  I hope everyone enjoys the holiday weekend while remembering why the holiday exists...
Rob
rob289c
Looking forward to how this turns out and more importantly how it holds up. On my Datsun 510 I filled the cracks with spray foam and then sanded. Then I bought a sheet of vinyl and wrapped it. But that dash didn't have the complex curves of the Pinto.
Ah, progress... one of my favorite things!  Glad to know you're back at it!
Dwayne :)
rob289c
I finally did something other than look at my project.  I made repairs to my cracked and otherwise unsightly dash pad. I used a heat gun and razor knife in the areas of the large cracks and dug out the bad foam too.  I filled the deep crevices with crumpled aluminum foil, then regular body filler.  After fully cured, I used a lightweight, flexible body filler (Porpoise Putty) and skinned and sanded it smooth.  See before and after below.  Future treatment will be adhesion promoter, primer/surfacer, then the black paint the rest of the interior parts will get.  Progress...
rob289c
It sounds like you got a few things accomplished over the weekend, and that's a good thing!
Dwayne :)
rob289c
Yesterday I rearranged my garage and got my toys accessible.  The Harley got it's annual oil and primary fluid changed.  It doesn't get tranny gear oil change this year.  I put the battery in the Mustang and fired it up.  Took it to the end of the street and back.  Only put 500 miles on last year so no oil change.  Re-torqued the lug nuts as I bought new tires last Fall just before putting putting it away.  Glad I did...there were some that were loose.  The project car just got rolled around and admired.  I think the first things I will do is repair the cracks in the dash pad and get the rest of the interior parts (dash, steering column, rear interior quarter panels, rear package tray, junk tray) ready for adhesion promoter, primer, black paint.  I have to work in some gardening/weeding and other home projects, then a week in FL at the end of the month but I plan to make some progress in the next few weeks.
rob289c
Sounds like a relatively simple and inexpensive way to keep your otherwise functional truck alive and well.  Looking forward to seeing the next phase of work on the roadster.
Dwayne :)
rob289c
I think next week my Winter Storage barn returns to workshop status!  I will be starting back up on my project.
Unrelated, I have an 03 Ranger with a rotted bed.  There is rot around the wheel wells and the bed floor.  If there wasn't a bed liner in it, it wouldn't hold any cargo.  Today I just bought a Mazda bed from a guy that gets them from NC.  Rust free and the same color.  The body lines are slightly different, but it will bolt on.  I will clean up the underside, epoxy, enamel, then coat with fibrated roofing tar.  That will get me a few more years out of the truck.  While the old bed is off, I'll clean up and seal the frame with POR 15 or similar.  The left side wheel well is way worse than the right side in the pic.
rob289c
