Pinto drive train
Date: 06/29/2018 08:32 am
pinto parts for sale
Date: 07/25/2018 04:51 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
KYB shocks
Date: 02/08/2017 07:09 pm
Date: 10/01/2020 02:00 pm
Date: 05/28/2017 03:20 pm
Date: 04/13/2017 04:56 am
Date: 11/08/2020 02:10 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
  • Online today: 802
  • Guests: 142
  • Total: 142
Door glass removal
Started by SpaceCowboy1979, May 25, 2020, 08:51:00 PM
SpaceCowboy1979
Glass is out
And in one piece
SpaceCowboy1979
Thanks again
     Tigger
Yes you will need to drill out the rivets. Don't loose the white plastic rings either. Hope this helps.
SpaceCowboy1979
Thanks TIGGER
I DID HAVE THE WIPES REMOVED
when I said window sash I was referring to
The piece attached to the bottom of the window.
I have onley removed door glass 2 or 3 times
And that was 25 years ago.
I think I have to drill out rivets on said piece
And take off of glass so it can be removed  from the door.
Its been a few years since I took apart a door.  From what I remember, I think if you remove the regulator frame from the lower part of the glass you can remove it without removing the dew wipes.  If you are trying to remove the glass with the frame, I believe the dew wipes will need to come out.
SpaceCowboy1979
I am trying to remove the door
Glass from my 1979
Pinto wagon
Do I have to remove the window
Sash to get it out ?
