Clutch Fork
Date: 03/31/2018 09:12 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Radiator
Date: 05/27/2018 06:07 am
1976 Ford Pinto
Date: 07/16/2019 02:51 am
pinto parts for sale
Date: 07/25/2018 04:51 pm
Date: 08/24/2018 02:50 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
  • Online today: 600
  • Guests: 480
  • Total: 480
rear shocks
Started by little76er, March 05, 2020, 04:48:41 PM
davidpinto
MONROE USED TO LIST # LE10026 FOR PINTO WAGONS 74 & LATER THEY ARE NLA NOW.COMP. LGTH WAS 10.375 /EXT. LGTH WAS 16.875/TRAVEL LGTH WAS 6.50.I FOUND A SHOCK # 32112 MONROEMATIC PLUS THAT MOUNTS THE SAME TOP & BOTTOM  COMP. LGTH IS 12.250/EXT. LGTH IS 20.250/TRAVEL LGTH IS 8.250.PRETTY CLOSE,MIGHT WORK ON STOCK RIDE HGT.NOT ON LOWERED CAR,# 32112 ARE READILY AVAILABLE,WORTH CHECKING OUT.
D BARHAM
Les
For Station Wagon Momroe #5826.
little76er
That's great to know, thank you for your input, I was wondering how to replace shocks after I ware out the one's I have.
I think l'm going to use an Explorer 8.8 rear end with disc brakes so l'll probably have to fab something but those might still work. Thanks for the info
flash041
Late 70's Camaro shocks work. They are about 2 1/2 inches longer, but compressed length is
about the same.
Thanks l guess l'll figure it out when l get to that point. l plan to lower it at least 2" so......who knows what will work lol
Do at your own risk but I used the regular sedan shocks and just used spaces to "center" the shocks on my wagon. Damper wise I don't know the difference but the length I believe is about 2" longer. The spacers made up about 1-1/2" and the rest I have never noticed. Note that I only show this on the bottom but I did it at the top too.
Most shock manufacturers have the shock end and travel length listed on their websites. Perhaps you can find something that way.
Back in the day.....a long, long time ago (LOL) I could and did, go to parts stores & give them the stroke & pin/eye measurements & get shocks that worked.
little76er
they fit but I got them from a man in Wa. state, there used, I never could find any new one's.
Any ides what the ones you found fit? Because l am going to need some for the wagon l am building!
little76er
I did find a set of shocks that will work, they are used but are in workable condition. Mine is a wagon but I can't find any new shocks listed anywhere except the one's listed for the mounts that require the brackets. That's ok, I don't think I will ever drive the car enough to where out the shocks.
The shocks on both of my cruising wagons have two studs or maybe two bolts (?) but there is no plate with three mounting holes. Must be just for non-wagons. So are you saying there are no shocks available? Because l don't see any listed for a wagon on RockAuto!!
Let me do some research   :)
little76er
Hi, I need some help trying to figure out what type of rear shocks on my 76 station wagon. I have parts from 3 different pintos and all the rear shock upper mounts are the same. Trouble is my car is different. The upper mount has only 2 studs fixed to the body not the 3 holes for the typical mount. I cannot find any shocks that will mount to this type of set up, i'm sure it's factory because it doesn't look altered. Any help would be very useful. Thanks, Dale
