Date: 10/24/2018 07:41 am
Date: 10/25/2019 04:05 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 03/29/2019 07:20 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Interior Parts
Date: 08/07/2017 03:59 pm
  • Online today: 802
  • Guests: 142
  • Total: 142
Pinto U-Bolt
Started by PintoCDN, February 07, 2020, 02:52:32 PM
Opps, sorry Reeves. It was 71 Pintoracer that had the bad crash and the car was severely damaged. In my old age I get these racy looking Pinto's confused. https://www.fordpinto.com/general-pinto-talk/the-totaled-pintoracer-warning!!!-graphic-pictures!!/msg181977/#msg181977
Quote from: Wittsend on February 17, 2020, 11:04:30 AM
I think it depends on where you live (or more specifically were the car lived) regarding U-bolt replacement. For those of us in So. Cal. it is likely a non-issue. Reeves (who is listed as from cold/snowy Alberta) had a nasty car crash with his Pinto. So, I'd assume he has a better reason to change the U-bolts than myself.
Never had a crash......
U-bolts, regardless of where you live, stretch. Thought it was well known that they were never to be re-used.
When I put lowering blocks on my 79 wagon, I had u-bolts made from my local spring shop.  They were expensive.  The last 3-4 cars I have done, I bought u-bolts from my local RV supply place.  They are tons cheaper there and have many different sizes and lengths.
Quote from: Reeves1 on February 08, 2020, 08:05:47 AM
Don't re-use diff U-bolts. Get new ones from a spring shop (or jobbers) and TQ to spec & do not forget to re-TQ after driving one time.
I'm curious why they shouldn't be reused? For a high-stress build I can understand not wanting to, but I think PintoCDN is just running a warmed-over 2.3.
I seem to recall that the stock nuts are also distorted-thread locknuts. A lot of aftermarket u-bolt sets don't have locking nuts. A retorque on those I definitely recommend as well as periodic checks thereafter.
Billnparts
Any good spring shop can make you whatever you need.
Sent from my iPad using Tapatalk
Quote from: PintoCDN on February 07, 2020, 02:52:32 PM
Hello,
I intend to swap a 8" Mustang II rear axle and replace U-Bolts instead of 7.5".
The original was 6.75" rather than 7.5, but it doesn't matter here. The u-bolts from either will work.
I can't recall whether I got all the Mustang II parts when I bought my 8", or I used the existing from the 6-3/4" rear end. As you can see in the picture the 8" tube does narrow down. The center to center on the U-bolts is roughly 2-3/4". The inner half  circle of the U-bolt will be somewhat smaller. Sorry but it was 12 years ago and I just can't recall. Perhaps the pictures will help.
PintoCDN
Hello,
I intend to swap a 8" Mustang II rear axle and replace U-Bolts instead of 7.5". I am not able to find a part # or specs for it. Your help will be appreciated.
Jean
