Date: 08/22/2018 09:23 am
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Date: 04/04/2020 09:38 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 08/16/2018 08:54 am
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Date: 02/14/2019 06:27 pm
Date: 02/10/2017 09:30 am
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
  • Online today: 802
  • Guests: 126
  • Total: 126
Help Please
Started by Fair 73, October 10, 2019, 07:46:11 AM
Fair 73
Thanks guys I appreciate it.
PintoMan1
hi, to answer your question plane and simple is YES. I also have a '73 as pictured and you would never know by looking at it that I have doors on it from an '80 pinto.
like Wittsend says the front suspension is a bit different from the '71 & '72.
1973 pinto runabout
Specifically, I don't know if the fenders are the same.  However, it was between 73 and 74 that there were major changes so the Mustang II and the Pinto could share aspects.
My guess would be that the 72 and 73 fenders are likely the same. The major difference between the 72 and 73 as far as I know was the forward extension of, and support behind the front bumper. So, the rubbery piece between the lower end of the grill and the upper part of the bumper I believe is longer. Off the top of my head I'm thinking if anything was different it might be side marker lenses.
All that side Ford seems to be famous for changing things for no obvious reason. The 73 Pinto's has a one year only steering rack.  The 71-73 Pinto's had a different front suspension (and rotors). The wagons have longer rear springs and shocks.
Fair 73
 Hello
  I have a 73 pinto as pictured in my profile. I am looking at a 72 Pinto hatchback mine is a 73 with a trunk. My question is are the front fenders exactly the same between them along with hood and doors.  Or are there small differences.
Thank you
