1980 Ford AM radio
Date: 12/22/2019 11:57 am
free transmissions
Date: 11/28/2019 10:21 am
Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 08/22/2017 09:21 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 12/30/2022 01:30 pm
Date: 10/05/2017 02:26 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
  • Online today: 802
  • Guests: 144
  • Total: 144
Desmogging a 1980 wagon
Started by LongTimeFordMan, September 25, 2019, 10:00:31 PM
LongTimeFordMan
Thanks for the info.
I have a friend who is contemplating buying one and if he does will probably want to clean up the engine compartment.
use a early carb and rejet , the later ones had much less cfm flow , remove egr valve and block off , most likey clouged up by now , good exhaust system in order , you can use the tube type manifold off a ford ranger or the cast one off a last of the 2.3 rangers , toss the cats if you can , depends where you live , you can cheat buy removing the whole thing and tow the car to a muffler shop and tell them you want a exhaust put on , last is remove the cat sticker on the door jamb that say it has one , should be good to go
LongTimeFordMan
Whats involved in de smogging a 1980 2.3 engine
